Tyre Repairs
Submitted: Sunday, Jan 08, 2006 at 16:33
ThreadID: 29473 Views:1972 Replies:5 FollowUps:2
I have a 2005 GU Nissan Patrol with Factory 17in Allot wheels.
I have tried to carry out a tyre removal from the rim using my tyre pliers, but it creats alot of chips in the alloy around the edge.
Can anyone offer any advise??
Reply By: Martyn (WA) - Sunday, Jan 08, 2006 at 16:46
Corey K,
I had the same problem, took the Tyre Pliers back to where I bought them from and bought the R & R Beadbreakers, much better tool, bit more expensive but they work a lot better never had any problems since. My opinions and I don't have any affiliation.
Keep the shiny side up
AnswerID: 147206
Reply By: Truckster (Vic) - Sunday, Jan 08, 2006 at 20:16
put the alloys in the shed, and buy some cheaper steelys
not having used the tyre plyers, can you put something between the rim and the plyers to stop the chipping, like a piece of garden hose?
AnswerID: 147232
Reply By: Voxson (Adelaide) - Sunday, Jan 08, 2006 at 22:18
Its not the tyrepliers which cause the damage as i have peeled the bead as a test already but the hassle is the tyre levers...
Just take two spares and a puncture repair kit...
AnswerID: 147282
Reply By: Member - Drew T (VIC) - Monday, Jan 09, 2006 at 09:31
so does anyone know what are the cheapest 17" steel rims??
AnswerID: 147342
Reply By: Member - Phil G (SA) - Monday, Jan 09, 2006 at 10:15
2 suggestions:
Pretty much every puncture, short of a destroyed tyre can be repaired using a plug kit. Much easier than tyre levers, patches and you can fix the tyre without taking it off the car.
Secondly, Use a car jack or a high lift jack as your beadbreaker - much nicer to alloy rims. link to car jack beadbreaker
Tyreplier type Bead breakers are unnecessary piece of equipment in my opinion, but the shops love to sell them.
AnswerID: 147351
Follow Up By: Member - Drew T (VIC) - Monday, Jan 09, 2006 at 12:18
but as Voxson says .. its the tyre levers that cause the most damage to the rims
FollowupID: 400691
Follow Up By: Member - Corey K (VIC) - Monday, Jan 09, 2006 at 20:04
Thanks for the advice Phil,
I'm going to have a go at making the attachment for the toyota vehicle jack this weekend.
Cheers, Corey.
FollowupID: 400816
