Oil Info requested
Submitted: Sunday, Jan 08, 2006 at 22:04
ThreadID: 29487 Views:2290 Replies:3 FollowUps:0
I am after some info for a friend regarding oil. He has a 1997 Landcruiser, 4.5lt petrol, Auto Trans. It is only ever used to tow a 2 horse float(he and his wife are in the horse racing game). The car currently has 156,000km on the clock.
What grade of oil and what type of oil should he be using? Should he be changing the oil more frequently(5,000km) noting the vehicle is always towing.
Any info greatly appreciated.
Reply By: herkman - Sunday, Jan 08, 2006 at 22:54
If it were mine I would change the oil every 5000
Any good oil, particularly one which will hold the soot in suspension, will stop the engine wear to the minimum.
I would also ensure that the transmission was flushed completely at the interval laid down in the service manual.
Col Tigwell
AnswerID: 147293
Reply By: Martyn (WA) - Monday, Jan 09, 2006 at 00:41
Jason,
oil should be a 15W-40 or a 10W-30, slightly heavier weight would be better considering the service, a good quality oil would be 10,000 I would of thought. Filter change same as the oil. Auto trans is an Autran DX 2 or 3. The Autran DX2 has slightly better anti foaming properties than the 3. Capacity is 6.0 litres.
My opinions and views as usual. Hope this helps, perhaps a synthetic, has better properties, lubricity, anti soot, stability and better heat dissipation, costs considerably more by pays for itself in the long run.
Keep the shiny side up
AnswerID: 147309
Reply By: peteC - Monday, Jan 09, 2006 at 17:59
Jason,
Try this castrol site for oil info. The link will may give you the model your after, if not search for the one you need
http://www.datateck.com.au/lube/castr_au/default.asp?Section=2&Make=108&Model=2628
AnswerID: 147445
