gps to laptop
Submitted: Wednesday, Jan 11, 2006 at 18:55
micanddeb
HI ALL,
Can any one tell me if you can get an addaptor to run a magellan gps on a laptop with no comm port to suit, this is a new laptop.
My home computer has this port and the gps works fine.any help would be appreciated.
Reply By: Member - David (WA) - Wednesday, Jan 11, 2006 at 19:07
If you have a laptop with USB ports you can get adaptors to convert the serial cable from the GPS to USB so it plugs into the laptop.
Not sure if this site
shop has then but dick smith should. You may need to load the drivers as
147845
Follow Up By: Member - David (WA) - Wednesday, Jan 11, 2006 at 19:13
The site
shop has then for $39 + postage.
David
401152
Follow Up By: Terryfied - Wednesday, Jan 11, 2006 at 19:51
You are lucky its not a garmin $142.00 for the garmin usb to serial adaptor.
Terry
401157
Follow Up By: WillyWish - Wednesday, Jan 11, 2006 at 21:01
Terry,
Why not just use a generic usb to serial? Garmin and Magellan accessories are just too expensive!
Will.
401174
Follow Up By: Terryfied - Wednesday, Jan 11, 2006 at 22:16
Will, I originally bought a generic brand,however no matter how much we tried (even with different settings and configurations) the garmin would only work with its own branded cable.
I do believe GPOZ have a similar cable for $90.00.
Terry
401200
Follow Up By: WillyWish - Wednesday, Jan 11, 2006 at 22:32
Hi Terry,
What Garmin GPS are you using?
Will.
401209
Follow Up By: Terryfied - Thursday, Jan 12, 2006 at 19:10
Will, I use a garmin 60c.
Terry
401380
Reply By: Member - AdrianLR (VIC) - Wednesday, Jan 11, 2006 at 19:34
I use the one from Jaycar for a Magellan 315 with a HP4200. Works fine. You'll need to check the port assignment the laptop gives the adapter (
mine defaulted to COM6) so that you can tell your mapping software where to look.
Adrian
147854
Follow Up By: Member - AdrianLR (VIC) - Thursday, Jan 12, 2006 at 00:13
Also important - you must install the software that comes with the adapter. It won't work without it.
A couple of other hints that others have mentioned in previous posts - turn the GPS on before the computer otherwise the port may be recognised as a mouse and always use the same USB port so that the com assignment doesn't change.
The ebay version has given variable results
401242
Reply By: WillyWish - Wednesday, Jan 11, 2006 at 21:03
Can get them off ebay also. I also have a magellan but opted for a $90 usb GPS which is permanently mounting in the car for use with laptop.
Good luck!
Will
147883
Reply By: Keith_A (Qld) - Thursday, Jan 12, 2006 at 10:09
The adaptor is the solution, however you will probably find your mouse pointer takes on a life of its own. Reason - Windows detects the USB to Serial Adaptor as a pointing device - eg mouse.
Sugestions :
1. As above - always plug the USB into the same port.
2. To solve the mouse pointer problem - with the cable disconnected, go into :
control panel/system/harware/Device Manager.
Select Mice and other pointing Devices.
Locate the 'new' one and click disable.
With the device disabled, you never get the 'mouse out of control' problem again.
regards......................
147979
