HJ60 diff with LSD
Submitted: Thursday, Jan 12, 2006 at 08:06
ThreadID: 29599 Views:5219 Replies:3 FollowUps:0
Goodday,
Need to replace diff carrier in HJ75 troopie, able to acquire a HJ60 diff with LSD from a wreaker in good condition. Problem, unable to tell me the what Diff ratio it is, but says it is likely to be 4.11 nor could he tell me if it was from a cruiser with auto or manual gear box.
What ratios were there for the diesel 60 series? and is the crown and pinion gears the same as a non LSD diff?
Thanks guys for any help here
Reply By: Member - DOZER- Thursday, Jan 12, 2006 at 09:27
The said diff is a 4.11 as r all of the 60 diffs....it will fit straight into the hj75....which also has 4.11 ratio...
Go for it.
AnswerID: 147966
Reply By: desert - Thursday, Jan 12, 2006 at 12:01
Don't rely on anybody telling you it SHOULD be 4.11. You already know that. Don't take the wrecker for his unreliable word either, he wants your cash after all.
Inspect the diff and count the number of teeth on the pinion. Divide this number into the number of teeth on the crown wheel (the big gear). This is the true ratio.
AnswerID: 148007
Reply By: Ascot - Sunday, Jan 15, 2006 at 07:03
Thanks Guys,
At the end of the day there remains an uncertainty as to the condition of the LSD, more navel gazing required here, thanks for your responses
AnswerID: 148672
