Reversing cameras
Submitted: Thursday, Jan 12, 2006 at 15:55
Austravel
Noticed a thread on LCD screens but wonder if anyone has brought the complete reversing camera/screen packages. I'm thinking of one as we have a canopy on which makes it a little hard around town.
Any
views on what or what not to buy/look at?
Reply By: Member - Paul P (Bris) - Thursday, Jan 12, 2006 at 16:15
G'day
Some of the reversing kits have screens that can only be mounted on a dash. Other options allow for windscreen mounting. Be aware that mounting these screens on the dash or windscreen usually causes a breach of the ADR vision requirements in later model vehicles
Removing the internal rear vision mirror would also probably be a breach of the ADR's, even though you cannot see anything out of it.
Other options are replacing the radio setup in your vehicle with a combo foldout/electric roll out video screen and radio/CD combo combined with a suitable camera. Think ahead. Do you plan running a nav computer system in the future?. If so a screen that works with a computer as
well as the rear camera would be worth the additional initial dollars.
I ended up with the replace radio option and a suitable camera. Not cheap but I now have a better sound system than the original plus a multi input capable DVD screen.
Paul
148072
Reply By: Noosa Fox - Thursday, Jan 12, 2006 at 17:18
We have a camera in the tail
gate of the F250 and another on the rear of the caravan. I can switch between them using a switch on the dash. The screen is a fold down type that is mounted on an overhead consul, and I have it mounted in front of the interior mirror.
Can't see out the mirror with a van on anyway, and as it is in the normal rear view possition it does not distract when glancing into it.
Ours was all fitted by Sound In Motion, Nambour QLD.
The one in the tail
gate is very good for hitching up the van and seeing what is behind when
parking. The one on the van is very good for when you want to change lanes after overtaking as when you can see the front of the vehicle in the adjacent lane, I know that I am at least 2 metres in front of it.
Brian
148085
Reply By: Rob Ackland - Thursday, Jan 12, 2006 at 17:26
We have done a fair bit of evaluation on reversing cameras and I am currently using one on the new Prado. Combined with reversing radar and remembering to always check your mirrors as
well the combined
tools are a real plus.
Issues to consider are these:
- Infared colour is best. It provides visibility beyond your reversing lights at night. No other system provides that flexibility and it is a must have
- Any system should be
well and truly
water and vibration proof if it is going to survive on a 4wd
We are using a Poron system model CM-V1. THis provides a colour IR camera, with wide angle lens, to IP 63(waterproofing standard) and an LCD screen which can be mounted from the sun visor and swings away when not wanted. The screen can also be used to take a feed from a PC so it is quite flexible. Works a treat and you should be able to get one fitted for less than $450 I would think.
As something else to think about our screen is mounted on the passengers visor as it is much easier to see and use from the drivers
seat. You don't need a screen in our face as you would if it was mounted on the drivers visor.
Rob
148086
Reply By: Member - Roachie (SA) - Thursday, Jan 12, 2006 at 17:28
Mine is the Poron version which 3 of us got as a bulk purchase 6 months or more ago.
The screen came with a mounting plate which was designed to be attached to the dash with double-sided tape. However, I had long previously removed the internal mirror of the Patrol (and had nothing there at all for over 12 months). So, I dragged it out of the shed and took the mirror off it's mounting bracket....made up a piece if steel into an almost right-angle and mounted the screen where the mirror would have normally been. It still has the safety "break-away" feature that the original mirror used, so that in case of an accident, the whole lot will come away instead of being a solid object for the head to ram into.
Works
well and is the same as the ones currently being advertised in the 4x4 mags for $400-+ (we paid about $300-).
Mine only has one camera, but there is a vacant plug socket, where another camera can be plugged in (if you want one on trailer/caravan etc). Switching between the 2 cameras is done via a button on the side of the screen.
148088
Follow Up By: Austravel - Tuesday, Jan 17, 2006 at 11:06
Thanks Roachie, how
well does it work at night?? Do you have a contact I can use to try and get the same deal??
402267
Follow Up By: Wayne (NSW) - Tuesday, Jan 17, 2006 at 15:49
Austravel,
I would agree with Roachie all the way. I have the same camera and set up and the unit has done a lot of outback travel, Canning, Simpson crossings, Flinders and 4
Vic High Country trip and has never mist a beat.
I have the camera on all the time that I am in the vehicle and have not had any problem with the screen. The camera is mounted up high on the back of the roof rack so I get a good view of the back of the vehicle. I am now thinking of putting a camera on the front of the vehicle, just because I can.
Wayne
402307
Follow Up By: Member - Roachie (SA) - Tuesday, Jan 17, 2006 at 16:42
G'day Austravel.....
John from Vic (troopy) did the negotiations with the bloke in Queensland for the deal.
It might be timely to start a new THREAD to see if there are any more EO people interested in getting into a bulk purchase. I was surprised that only 3 people ended up doing this when we got our about 9 months ago.
The site is : www.poron.com.au
The system works reasonably
well at night. Like Wayne,
mine stays on all the time and only turns off when I isolate the 2nd battery. At night all I can see when driving forwards, is the spare tyre, highlift jack and a small patch of the road....all "lit up" courtesy of the infrared feature. However, when I hit reverse gear (with 2 spotties on the roof rack beside the camera), the whole area behind the vehicle is easy to see.
Great set-up and the best $300- I've spent in a long time!!!
Roachie
402312
Follow Up By: Austravel - Tuesday, Jan 17, 2006 at 16:45
Thanks for the info. May look at doing something in the near future.
402314
