2001 GU Patrol Front Auto Hub problem
Submitted: Sunday, Jan 15, 2006 at 12:54
ThreadID: 29716 Views:2833 Replies:6 FollowUps:1
Travelling home the other day doing about 100kph on the Hume a loud rattling noise started coming from the drivers side front wheel hub. I stopped and had a look but couldn't see anything obvious. Continued on the noise was gone, about 3 or 4 kilometres later it did it again, I pulled over to the side of the road and as I came to a stop there was a very slight clunk in the front end. I reversed to see if the front hub may have been still engaged as I had used 4wd earlier that day. Travelled the rest of the way home about 100 kilometres with no problem. Any ideas.
Reply By: Leroy - Sunday, Jan 15, 2006 at 13:41
Mate had the same issue coming back from a trip recently. Not sure what caused it but maybe the hub wasn't completely unlocked then along the way the autohub started to engage hence making the noise. Just reversed and appeared to be ok but did it again a few kay's later. It stopped after rersing again and hasn't come back.
Leroy
AnswerID: 148736
Reply By: Member -Dodger - Sunday, Jan 15, 2006 at 15:14
I had the same prob and it was the spring in the hub and still is. Solution = As the replacement part was very exy went and installed manual hubs now never happens. And yes I do have a lockrite in the front. Now soon as I think I may need 4wd lock the hubs and engage high range whenever it is warranted , back on black top unlock while pumping tyres and checking same.
Cheers Dodg.
AnswerID: 148752
Reply By: Member - Andrew (Bris) - Sunday, Jan 15, 2006 at 16:06
Had the same happen. Was the spring in the auto hubs.Choice was either replace the auto hubs - expensive. Went back to the ancient method - manual hubs. Did pick up some second hand auto hubs - one of these days I'll swap them back.
AnswerID: 148758
Reply By: jorgejhandal - Sunday, Jan 15, 2006 at 16:35
I had a similar problem with an old 92 patrol, and it was the pin that engages the four wheel drive in the gerabox(differential) its a spring with a pin it gets stuck sometimes and engages the fourwheel drive on
AnswerID: 148763
Reply By: Flash - Sunday, Jan 15, 2006 at 19:17
Above advice sounds right to me.
I infinitely prefer manual hubs anyway.... I have removed auto ones off my mates 4WD and he's much happier now than he was with the auto ones.
AnswerID: 148782
Reply By: David CREES - Sunday, Jan 15, 2006 at 19:53
Thanks for all your advice, I will see how it goes, have been driving it without a problem since.
AnswerID: 148791
Follow Up By: Muzzgit (WA) - Monday, Jan 16, 2006 at 01:45
I have had the same thing happen. Now when I have been in 4WD, after dissengaging 4WD and taking the hubs back to auto, I just reverse a few feet before taking off. It hasn't happened since I started doing this.
Muzz
FollowupID: 402020
