AnswerID: 148774 Submitted: Sunday, Jan 15, 2006 at 16:32
Member - David 0
replied:
Do you have an oil cooler?
There are a couple of possibilities I can think of. Remote as they are, they have been reported from time to time.
Oil held up in a cooler or oil filter is not supposed to drain back to the engine in most 4bs. A failure of a non-return valve or failures in oil cooler can result in oil draining back to the engine giving a false high oil level (the system is partially drained). This means that once running the oil pump could starve.
In any case I wouldn't drive it while it shows low pressure. One thing you could try, is to for a very short run, overfill the sump NOT TOO MUCH and see if that improves the situation. You would only need to overfill by 500mls or so. Don't drive it for too long in this state though.
 | A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do.
Reply 3 of 6
