Can I turbo
Submitted: Monday, Jan 16, 2006 at 22:16
ThreadID: 29768 Views:2325 Replies:6 FollowUps:2
I have a 1hz 4.2 litre diesel in my troopy.There are 250,000 km on the clock,the motor does not use oil or blow smoke and seems to be sound with no unusual rattles or groans.Turbotech in W.A can fit a Garret watercooled turbo with a 2.5inch exhaust for $3,500.
Do I need to make any modifcations to handle the turbo?
Terry
Reply By: Mouldy - Tuesday, Jan 17, 2006 at 01:26
Hi Terry,
Had the blokes there fit a turbo to my 4.2 GQ with 235000 on the clock, same deal, same cost, also got a snorkel. They did good job and the old girl goes like a shower of faeces now. No modifications needed. Ask Bill from turbotech if you are unsure bout anything. I'm off there tomorrow for a tighten up after the settle in of mine.
BTW I think I get better economy now, certainly when towing. Engine temp rises up to 3/4 of hot on a warm day working it hard, but I think that is helpful in fuel combustion anyway. Certainly doesnt overheat, which I was concerned it would.
good luck
AnswerID: 149070
Follow Up By: Member - Brian (Gold Coast) - Tuesday, Jan 17, 2006 at 08:34
Keep an eye on the radiator fins.... if you go off road, the dust gets in them and turns to mud in rain/puddles/creeks/rivers etc..... and slows down the heat transfer dramatically. I pull our radiator out every 3 or 4 months and thoroughly clean it and give it a light coat of paint and temp propblems are eased!
FollowupID: 402238
Follow Up By: Turbo Diesel - Tuesday, Jan 17, 2006 at 09:44
The difference between the GQ motor though is that nissan use the same crank and bearings etc when they bring out a factory turbo. The nissan motor may be a dinosaur as far as tech is concerned but its as tough as nuts. The 1hz is renowned for problems with the main engine bearings and for not being able to handle a turbo. I would make sure you get a warranty and look right into it, personally i wouldn't be doing it.
FollowupID: 402256
Reply By: scott666 - Tuesday, Jan 17, 2006 at 02:16
Hi terry I had a dts turbo fitted to my 1hz it had 220ks on it and had no problems I had west end deisel do the fuel pump up and they added a boost compensater to the pump it ended up having 99kw and 560nm of torque I was very happy cheers Scott.
AnswerID: 149076
Reply By: Member - Ian H (NSW) - Tuesday, Jan 17, 2006 at 07:40
Go for it Terry. I had one fitted to my 80 series at 150000kms and even without changing the exhaust the difference is staggering, a different car. Fuel consumption is not changed and I now get 136 kw and 395nm bit best of all I can lay rubber for 50 metres. I lied about the rubber laying but all the rest is true. Open your wallet and give them $3500, you wont regret it.
AnswerID: 149085
Reply By: Member - Toolman (VIC) - Tuesday, Jan 17, 2006 at 07:55
Terry
Ditto to everything Ian H has said although his bit about laying rubber had me thinking for a second. I had my Cruiser Series 80 done at 155K and its been great. A slight increase in fuel consumption (1ltr/100 km increase) but I think that is because of the way I drive it, now that I have all that extra grunt. No increase in temperature I've noticed.
Tom
AnswerID: 149088
Reply By: Member - Brian (Gold Coast) - Tuesday, Jan 17, 2006 at 08:40
250K's???? The motor's just run in! ;-)
Seriously though, we have just had our GQ turboed at 253K's.... and a mate has rebuilt his 80 series and added a turbo as well. I am very happy with ours, it has made such a difference!
Used a TurboGlide system from Russellvale in NSW, including the 21/2" exhaust and had injectors done as well and a big service to the truck. Goes like a rocket!
I can't see the 80 being any different, but check with a couple of mechanics as well to settle your mind.
AnswerID: 149092
Reply By: 120scruiser - Tuesday, Jan 17, 2006 at 13:22
I did my 80 at 273 00 km.
Get it compression tested.
Have the injectors done and most of all FIT AN EGT.
If these are not set up right they will crack pistons but when done right you will have no problems.
You can get these things cracking but they don't last for long. If the fuel is set wrong they can over heat as well. The EGT will tell you everything.
No higher boost than 8 psi and no higher EGT than 500 deg at full throttle for 2 minutes. Thats if the probe is directly after the turbine.
Don't be too worried so long as you have it tuned right.
120scruiser.
AnswerID: 149130
