frontera drive belt
Submitted: Tuesday, Jan 17, 2006 at 22:18
ThreadID: 29812 Views:4642 Replies:2 FollowUps:2
Hi, just wondering if anyone has ever changed a drive belt on a V6 holden frontera
Reply By: BennHW - Tuesday, Jan 17, 2006 at 23:05
Hi Pop,
Not sure what you mean by 'drive belt'. From memory I had a timing belt replaced at about the 50K service on my vehicle (2000 Frontera V6). I think it was about $150 on top of the service.
I'm interstate at the moment but can check my log book and receipts when I get home at the end of the week if you like.
Regards,
Benn
AnswerID: 149256
Follow Up By: Gerhardp1 - Wednesday, Jan 18, 2006 at 21:46
If you mean the serpentine belt, it's easy to change. I did mine with no problem (at around 70,000k, 4.5 years).
You just need to put a socket on the nut on the tensioner pully and push in the appropriate direction to release the tension on the belt, and off she comes.
Place the new belt on in reverse sequence and release the tensioner again with the socket and slip the belt over. It's a bit harder than taking the old one off because the new belt is a little stiffer and has slight memory from the way it is folded when you get it. I paid about $70 for the belt from East Coast Auto Spares in Melbourne.
Oh, and make a little diagram of how it goes over all the pulleys before you remove the old one, this will save you a potential headache and a half :)
FollowupID: 402737
Follow Up By: Gerhardp1 - Wednesday, Jan 18, 2006 at 21:47
Oops, forgot to add mine is a 3.5 litre Jackaroo but I think your belt would be the same.
FollowupID: 402738
Reply By: pop - Friday, Jan 20, 2006 at 12:46
Gerhardp1
Thanks for your reply, I did have a bit of a play and thought and did push the tentioner down by hand but wasn,t to sure I will try it tonight. Thanks for the idea about the diagram I had thought of that was going to take a photo.
AnswerID: 149834
