heat exchanger temp / flow
Submitted: Thursday, Jan 16, 2003 at 13:24
helton
Helton heat exchangers- test results flow rate verses temp output
www.helton.com.au/spesifications.htm
output from our own mod 1a heat exchanger
Tony
Reply By: OziExplorer - Thursday, Jan 16, 2003 at 14:11
Tony, your URL is incorrect, here is the correct one below:
http://www.helton.com.au/specifications.htm
I presume your graph output is tempreture °C and the flow is Litres/per minute Yes/No.
This is an interesting statement:
Quote
Do not drink
water! These heat exchangers are designed for showers and washing, copper is poisonous and
water should not be consumed.
End
How come we are not all dead? Copper is supposedly the superior product for domestic plumbing.
Are all the models $99.00? I had to dig to find the price.
If you click on the Order Model XXXX it takes you to a page with no prices or the ability to order, and when you click on the HOME button to get back to your website, it goes nowhere.
Not being critical, just advising you as I am sure you want orders.
11383
Follow Up By: Helton - Thursday, Jan 16, 2003 at 15:07
Too true -too fast on the keyboard
& yes deg c versus lts / min
The health warning is as per your home hot
water system whereby bubbles can cause the growth of copper oxide crystals which if released into the
water (maybe your coffee
water) can indeed adversely affect your health especially in a heat exchanger where the coils may not always be full of
water but will probably contain some moisture?
Yes all models are $99 + post & handling. Thanks for the info about the store and are desperately trying to remedy it.
6294
Reply By: Member - Cruiser1 - Thursday, Jan 16, 2003 at 18:07
An interesting way to get some free advertising.
Hope you're at least a
forum MEMBER..... :)
11395
Reply By: diamond - Thursday, Jan 16, 2003 at 19:31
i dont need to know heat and litres per minute.i got
mine monday hooked it up and the
water was wonderfully warm should have seen the mrs going off in excitment.lol no more cold showers now great unit
11399
Follow Up By: Oziexplorer - Thursday, Jan 16, 2003 at 20:01
Diamond I know exactly what you mean since we installed a 14 litre gas Truma hot
water system in our 4WD. Is just magic. What a difference from stuffing around with buckets and a 12v pump shower in the bucket.
Was just magic over Christmas and New Year holidays.
6312
