Lube
Submitted: Friday, Jan 20, 2006 at 09:51
Damien
Gday friendly 4x4 type of people
Referring back to the "Low Sulphur" topic, can anyone recommend an additive to add lubrication?
Reply By: Willem - Friday, Jan 20, 2006 at 14:59
I use Flash Lube for diesels.
Pour in 50ml for every tankful.
Seems to keep the fuel clean and the upper cylinders lubricated
Works for me
149854
Follow Up By: Member - Trevor R (QLD) - Friday, Jan 20, 2006 at 18:37
Willem,
How many K's on your truck now, and what makes you think the flash lube has made any difference ?
I am not a sceptic, I am just interested in your opinion and experience.
Thanks Trevor.
403211
Follow Up By: Willem - Friday, Jan 20, 2006 at 22:17
Trevor
My GQ has done 307.000
You may recall (I posted the same here a few weeks back) that I had a near mishap with the GQ by running out of
water on a hot day. I got the truck going again after a while and I put it down to the Flash lube upper cylinder lubricant that may have saved the day.
Look, I am no expert on these things. Far from it but by using a fuel additive one can only enhance the operation of the engine especially with diesels as one can easily pick up dirty fuel etc etc
I reckon that the Flash lube makes for smooth passage of the fuel through the system.
Some luminary may state that I am talking crap but that is the way I see it. :o)
403253
