OziExplorer v3.96 development version
Submitted: Saturday, Jan 21, 2006 at 09:34
ThreadID: 29944 Views:2995 Replies:2 FollowUps:3
Yesterday (20th Jan), a new version of OziExplorer was released. It is still under development.
History
Development Version 3.96.1a (January-2006)
The new features in this version required many internal changes to the software code. Please report any problems you find.
Fixes
*Some bug fixes but probably added many more because of all the internal changes.
Changes
*OziExplorer now supports skins which allow you to change the visual look and feel of the software. The Skin Manager is available on the File menu. 5 Skins have been provided, more will be made available in the future.
*Many changes have been made to how tracks are handled. The concept of making track points active is now gone (they are now always active). Separate buttons are provided on the track control to add or insert track points to track 1.
*The Track Control has had major changes, you can now make it any size, the list column widths can be altered and are automatically saved, the toolbar has changed to add new buttons and remove the buttons no longer needed.
*The Track List has been changed and can now load large tracks instantly.
*There are now numerous line styles for tracks. Use the Track Property dialog to set the line style. To open the track properties double click on a track in the track control list.
*Points are now always active.
*The Point Control toolbar has been changed to remove buttons no longer needed. The control can be resized but the column widths are not saved yet.
*The Selection menu and Selection Control now has options to select track segments in Track 1 and points in Point Set 1. These options can be used instead of using active points to delete and save.
Reply By: Member- Rox (WA) - Saturday, Jan 21, 2006 at 11:00
Pluto thanks for the info just updated.
AnswerID: 149984
Reply By: The Explorer - Saturday, Jan 21, 2006 at 16:35
Must of been a bug in V3.96.1a ....latest is now V3.96.1b!!
AnswerID: 150027
Follow Up By: Pluto - Sunday, Jan 22, 2006 at 00:54
You get that in beta versions...
FollowupID: 403485
Follow Up By: gramps - Sunday, Jan 22, 2006 at 01:04
hahahaha 'software' and 'bug free' are mutually exclusive terms. Should never, ever be used in the same discussion :))))
FollowupID: 403489
Follow Up By: The Explorer - Tuesday, Jan 24, 2006 at 20:28
Make that version V3.96.1c
http://64.71.184.220/dev/oziexp3961c_setup.exe
FollowupID: 404150
