BFG's 254/70/ R16
Submitted: Wednesday, Jan 25, 2006 at 13:23
ThreadID: 30097 Views:3423 Replies:5 FollowUps:1
G-Day all, I'm considering putting BFG's size 254/70/ R16 on a DX 80 series. I would love to put on 265's but I'm concerned they would be too wide without flares. Does anyone have the 245's on their DX and how do you find them?
Hope this rain clears up (Sydney) for Aussie Day!
Reply By: desert - Wednesday, Jan 25, 2006 at 13:42
Damien, you'll find the 245's, a wee bit too small in overall diameter. They work out at around 29inch in the old money. About the size you'd find on a Hi-lux. I would suggest the 235/75x16 which you can still run on a 7 inch rim (or a split rim) without needing flares.
AnswerID: 150796
Follow Up By: desert - Wednesday, Jan 25, 2006 at 14:21
Opps, that should have been 235/85X16. Sorry
FollowupID: 404346
Reply By: Redback - Wednesday, Jan 25, 2006 at 13:54
What about 235/85/16, there standard fitment to a Defender, which have 7" rims, also 255/75/16 and 245/75/16 will go on 7" rims.
These are all suitible for a 7" rim, the 235/85 being the biggest and basicly the same as the old 750/16 fitted to split rims
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/85-16 7.9in 15.9in 31.7in 99.7in 636 0.0%
255/75-16 7.5in 15.5in 31.1in 97.6in 649 -2.1%
255/70-16 7.0in 15.0in 30.1in 94.4in 671 0.0%
245/75-16 7.2in 15.2in 30.5in 95.7in 662 1.4%
metric sizes
Specification Sidewall Radius Diameter Circumference Revs/km Difference
255/70-16 178mm 382mm 763mm 2398mm 417 0.0%
245/75-16 184mm 387mm 774mm 2431mm 411 1.4%
235/85-16 200mm 403mm 806mm 2532mm 395 0.0%
255/75-16 191mm 394mm 789mm 2478mm 403 -2.1%
Hope this helps
Baz.
AnswerID: 150803
Reply By: Turbo Diesel - Wednesday, Jan 25, 2006 at 13:57
Damien
I ran 26575R16 on my dx 93 80 series and they where fine, I picked up a set of the steel 16 x 7 prado rims. Perfect match the rim fitted ferfectly, tyres where flush with the guards but didn't protrude out at all. The 255/70/R16 in my opinion are a little small.
AnswerID: 150805
Reply By: MrBreeze - Wednesday, Jan 25, 2006 at 16:11
Damien,
I run exactly the same size as Turbo on my '93 DX,no problems at all without flares.They look pretty good too.
AnswerID: 150841
Reply By: Bonz (Vic) - Thursday, Jan 26, 2006 at 08:54
I had 235/85 16's on my Mav and found them to be excellent, bit wider, bit higher and no flares required. I got BFG Radial Trac Edge's and did 50000 on them and they stilll had better than 50% of original tread depth. Most satisfying, I actually took them off when I sold the Mav and sold them seperately.
AnswerID: 151010
