REPEATER- MODBURY_SA_Adelaide
Submitted: Saturday, Jan 28, 2006 at 01:05
ThreadID: 30180 Views:2958 Replies:6 FollowUps:9
I have been picking up repeater signals on CH7 a few times in the last couple of weeks. Revertive only, no conversation.
This has been from the mobile, short arial mounted on the roof, so could not have been too far away. From memory was on McIntrye Rd. Modbury North.
As far as I know there is only CH1 & 3 in the metro area.
Does anyone know if there is a new repeater installed in the general area.
Russ
"Prickle"
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Jan 28, 2006 at 01:25
I dont understand the Q chn 7 is a repeater channel and is often picked up by me travelling with repeater opening tones from nearby stations. Mt monger from memory is one. It should come as no surprise thaqt someone is using it
AnswerID: 151387
Reply By: Michael Carey - Saturday, Jan 28, 2006 at 09:29
I think there is a channel 7 repeater on Yorke Peninsula. I often get it from Port Lincoln.
AnswerID: 151407
Follow Up By: Russ - Tuesday, Jan 31, 2006 at 20:34
Michael,
Thanks for your response. Just that This is the first time that I have picked it up in the area, so wondered if a new one had been installed nearby.
Thanks.
Russ.
FollowupID: 405702
Reply By: PE250 - Saturday, Jan 28, 2006 at 09:58
the aca web site is a good place to look. you put in a postcode and all licenced radio and tv operators in that area will be displayed, including amature.
AnswerID: 151414
Follow Up By: Russ - Tuesday, Jan 31, 2006 at 20:35
Thanks mate, will have a look some time.
Russ
FollowupID: 405703
Reply By: Member No 1- Saturday, Jan 28, 2006 at 10:44
there is a bloke out that way who does mods to cb's and if i am not mistaken he has a repeater set up which he uses now and again
AnswerID: 151424
Follow Up By: Member No 1- Saturday, Jan 28, 2006 at 10:46
illegal maybe..... but so too are cb's transmitting more than 5 watts...some are pushing 30
even tx 4000 can do 8 watts
FollowupID: 405060
Follow Up By: Mad Dog (Australia) - Saturday, Jan 28, 2006 at 11:11
yep illegal repeaters are not uncommon
FollowupID: 405066
Follow Up By: Scubaroo - Saturday, Jan 28, 2006 at 11:56
Often while driving around Melbourne in scan I will pick up conversations between guys sitting at home talking on UHF base stations - have heard one guy giving detailed instructions to a teenager before on how to set up your "own" repeater station, and another guy talking about one he had set up. Basically just a pair of off-the-shelf UHF radios linked together, receiving on one channel and broadcasting on another, presumably using a line in/line out to connect?
I would understand that technically they are illegal?
FollowupID: 405072
Follow Up By: Russ - Tuesday, Jan 31, 2006 at 20:37
Thanks, may be that is the answer, it was a pretty strong signal.
Russ
FollowupID: 405705
Reply By: D-Jack - Saturday, Jan 28, 2006 at 11:59
This is not an answer to your question, but why on earth would you want to listen o the garbage and trash talk by brain dead morons that inhabit the uhf chanels in metro Adelaide? I have plums growing on my tree at the moment with more brains. Sorry, but some have mentioned higher wattage and illegal repeaters, but what about the trash talk in contravention of legislation???
D-Jack
AnswerID: 151433
Follow Up By: Member - Camper (SA) - Monday, Jan 30, 2006 at 22:20
Just paid for my new UHF today and it will be fitted next Tue so I'm new to this. Is there any channel in Adelaide used by non-morons or will I have to wait 'till I get out to the bush?
Camper
FollowupID: 405529
Follow Up By: Russ - Tuesday, Jan 31, 2006 at 20:41
D-Jack,
"why on earth would you want to listen o the garbage and trash talk by brain dead morons that inhabit the uhf chanels in metro Adelaide? "
Didnt say that I did, but I have and they along with ch 40 are not selected, hence a surprise when I picked up a strong signal on ch7 in the Adel metro area.
You are correct though.
Russ
FollowupID: 405707
Reply By: Member - Stephen L- Sunday, Jan 29, 2006 at 13:07
Russ
Channel 7 Repeater is here in the Clare. Depending where you are at the time and the type on antenna, it is possible to get it very easy in Adelaide. The top part of Brighton Road from Seacliff I and talk to people back home in Clare
AnswerID: 151602
Follow Up By: Russ - Tuesday, Jan 31, 2006 at 20:42
Stephen,
I spose this is possible, was up high, may the weather conditions contributed. Who knows.
Russ
FollowupID: 405709
