NAVARA TYRE SIZE 265 70 16
Submitted: Saturday, Jan 28, 2006 at 20:19
J.P.
OWNER OF A 05 DX NAVARA WITH STANDARD 205 16C , IM LOOKING TO SIZE UP TO 265 70 16 NARVARA RIM DOES ANY ONE RUN THIS SIZE AND OPINION ON PERFORMANCE.
I DO A LOT BEACH 4WD IN THE NORTH WEST.....
Reply By: Member - toohey - Saturday, Jan 28, 2006 at 21:14
g'day j.p
i went 245's with sunraysia rims this has proved to be for my requirments good enough,the standard rims in my opinion are to narrow for what you want to do.
cheers toohey.
151529
Follow Up By: J.P. - Saturday, Jan 28, 2006 at 21:24
GOOD CALL, I LOOKED AT THAT SIZE AND THEY FIT
WELL. JUST WOULD LIKE TO RAISE IT A LITTLE EVEN IF IT IS ONLY 20mm.
THANKS FOR FEE
J.P.
405145
Reply By: ats11279 - Saturday, Jan 28, 2006 at 22:52
J.P. I currently run 265/70r16 Maxxis A/T on my '04 DX dual cab, seem to work fine, however I have noticed they tend to wander on the bitumen if there's any
water lying around. This I believe after talking to others that use the same tyre is in fact the tread pattern. They have been great on the highway towing 2 tonne, fine in the local forest, haven't had them on the sand yet though!
Cheers Anthony.
151548
Follow Up By: Member - toohey - Sunday, Jan 29, 2006 at 06:35
i think the dual cab has wider rims,they come standard with 255's
cheers toohey
405178
Follow Up By: ats11279 - Sunday, Jan 29, 2006 at 20:17
My apologies, I appear to have misread the original post. I don't use the standard rims, but 7" wide alloy rims.
cheers Anthony.
405246
Reply By: MattyM - Sunday, Jan 29, 2006 at 08:21
J.P,
The DX navara came standard with a 6" rim & the local tyre service told me that you shouldn't go wider than a 225. The ST-R came with a 7" rim & a 255 tyre.
If you want to go to a 265 you will need 7" rims. Also 15" dia rims wont fit unless you grind away part of the brake caliper.
Hope this helps
Matty
151572
Follow Up By: Russel & Mary - Monday, Jan 30, 2006 at 08:55
15" rims do fit, you just have to check the offset is enough to clear the caliper. I have two sets. 245x16 and 31x10.5x15.
405327
Reply By: Tessysdad - Sunday, Jan 29, 2006 at 18:24
This could raise the skinny v wide debate, but here we go. Firstly I will say that I run 265/76 x 16 on my Patrol. They work fine in all the circumstances, including sand at the right pressure. The importnt thing to remember is that diameter is probably more important than width in sand, as when you let some air out the footprint lengthens and gives better traction. There is less chance of planing on sealed wet roads too. On 6" rims a good size would be 235/85 x 16.
Happy
camping,
Mike.
151626
Follow Up By: J.P. - Sunday, Jan 29, 2006 at 23:56
g'day mike
im heading the way of wider cause i dont want to lose out on power with the greater o.d.
Would you know the o.d. of 235/85-16.
I'll probrably end up running 255/70-16.
cheers buddy...
J.P.
405304
Follow Up By: gramps - Monday, Jan 30, 2006 at 07:24
JP,
Try this link for your calculations
Tyre Calculator
405311
Follow Up By: Tessysdad - Monday, Jan 30, 2006 at 13:46
G'day JP,
It's easy enough to calculate. 235 is width and 85 = 85% of the width. I calculate a difference in the o.d to be 42.5mm. If you can take the 16"dia. as a given then you have 844.5 (235/85) as against 802 (255/70). Be interesting to see how calcs stack up to the tape measures out there - or follow gramps's suggestion.
Happy
camping,
Mike.
405373
Reply By: Member - TonyG (Qld) - Sunday, Jan 29, 2006 at 21:08
I upgraded to 265/70 r15, dunlop A/T
Car runs fine, so steering problems, much better in the wet than standard tyres.
Just watch the speedo as it knows is out by about 5% (ie travelling faster than speedo says)
TonyG
151665
