Radiator-80 series landcruiser
Submitted: Sunday, Jan 29, 2006 at 17:54
ThreadID: 30215 Views:10681 Replies:4 FollowUps:5
Does anyone know of a modification to change the original 80 series radiator to a more reliable radiator. Our last 2 radiators have failed on the core edge after extensive travelling on corrigated dirt roads.
Swoosh
Reply By: matt000 - Sunday, Jan 29, 2006 at 18:59
assume you have copper? do they fail where the sides are soldered to the top tank?
AnswerID: 151632
Follow Up By: Swoosh - Monday, Jan 30, 2006 at 07:59
Radiator is alluminium core with plastic tanks. Fails on side of core about 100ml up from the bottom.
FollowupID: 405313
Reply By: matt000 - Sunday, Jan 29, 2006 at 19:14
How would you feel about leaving out 1 of the top mounts, so it is located at 3 not 4 points. Trucks, and even my 1944 jeep are mounted at 3 points,- handles twisting better.- assuming this is the cause of failure.
When I was mining, corrosion would cause the cores to move apart, breaking the sides out of the top tank. We only had Landcruisers. The roads were always salty. Corrosion was a real problem and they only lasted a few years.- that was copper radiators, the alloy ones didnt last that long.
AnswerID: 151635
Follow Up By: Swoosh - Monday, Jan 30, 2006 at 08:03
Thanks Mattooo, it probably is a twisting problem and we will heed your advice.
FollowupID: 405314
Reply By: Peter 2 - Sunday, Jan 29, 2006 at 19:41
according to the local radiator bloke the problem is twofold, the radiators are quite thin metalwise and don't handle the flexing very well and the second problem is that Toyota or whoever makes them uses the minimum amount of solder to hold it all together. Even if you stop the fatigue they will eventually let go as the coolant flowing inside actually wears the metal away.
I found that once the first two tubes on the drivers side had been repaired that it took quite few years before any more failed.
AnswerID: 151639
Follow Up By: Swoosh - Monday, Jan 30, 2006 at 08:06
Thanks Peter, these both have been original radiators and have, like yours, failed on the drivers side.
FollowupID: 405315
Reply By: Member - Davoe (Widgiemooltha) - Sunday, Jan 29, 2006 at 20:32
Are you talking the original plastic tank rad or the replacement copper tanks ones? When you replace an 80 series rad any reputable rad dealer will recomend you spend the extra 50 bucks on the copper tank version
AnswerID: 151652
Follow Up By: Swoosh - Monday, Jan 30, 2006 at 08:12
Thanks Davoe, this could be the answer to our problem. I'll try a copper radiator this time.
PS where is Cape Culver?
FollowupID: 405318
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Jan 30, 2006 at 15:36
When i bought my 80 I knew the rad was stuffed and the rad guy strongly suggested i spend the extra 50 bucks on the copper tanked rad (I think it is copper) Pt Culver is about 200km east of esperance and can be accessed about 70km east of Balladonia and taking a track south. Or you can do a run along the beach about 70km from Israilite bay to where these cliffs start
FollowupID: 405384
