battery chargers
Submitted: Sunday, Jan 29, 2006 at 20:09
ThreadID: 30218 Views:3045 Replies:4 FollowUps:3
Hi everyone,
i'm after a decent 3 stage battery charger for topping up my battery when in the one place for more than a few days. its an exide extreme (70ah), i'll be using a generator to power the charger. am i better off charging for a few hours a day? or waiting until the battery is under 40% then charging?
after searching there seems to be a few good choices:
the c tek 7a is this enough? or would it take too long to charge?
the durst 15a
http://www.durst.com.au/ smart charger
also found this on ebay, it looks the same as the durst? anyone used these?
http://cgi.ebay.com.au/3-Stage-Smart-Battery-Charger-15Amp_W0QQitemZ4606547581QQcategoryZ102807QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
would appreciate any advice on chargers and approx charge times etc..
thanks
Reply By: Mike Harding - Sunday, Jan 29, 2006 at 20:12
Jaycar do (did?) a good one?
Mike Harding :)
AnswerID: 151645
Reply By: Member - Collyn R (WA) - Monday, Jan 30, 2006 at 11:15
Have a look at the new REDARC unit. Charges at five amps and outperforms conventional 10-amp chargers.
Oz-designed and made. Affordable. Has conventional, calcium, and AGM/gel programs. www.redarc.com.au
Have had one on trial for six months and most impressed with it.
Collyn Rivers
AnswerID: 151738
Follow Up By: DesC - Monday, Jan 30, 2006 at 15:35
Can you get bigger ones? or are they too bulky. My mate has a 35 amp charger that is pretty small and i think it is marketed by Durst, do you think that would be better or not?
FollowupID: 405383
Follow Up By: Member - Collyn R (WA) - Monday, Jan 30, 2006 at 17:19
Charge a few hours a day - battery will last much longer.
35 amp charger overkill - including for the battery!
Collyn Rivers
FollowupID: 405432
Reply By: Mike DiD - Monday, Jan 30, 2006 at 17:27
Whenever a Lead-Acid battery is at less than 100% charge the Lead or Lead Oxide in the plates changes to Lead Sulphate which progressively hardens. Eventually this will stop the battery accepting charge.
- so for longest battery life, always charge the battery as soon as possible.
Mike
AnswerID: 151847
Reply By: 4145derek - Monday, Jan 30, 2006 at 18:41
Smart Chargers are great thats why they are the only ones I sell. Durst, Solarforce and sidewinder all come out of the same factory.
The 15amp unit will run off a 1000w generator email me for a data sheet.
Regards Derek
AnswerID: 151874
Follow Up By: Mr Z - Monday, Jan 30, 2006 at 19:41
how many amps do they draw? (ac)
and what are they like compared to the c tek?
is the c tek smaller? and weather proof?
thanks
FollowupID: 405466
