80 series -Fuel Tank Fault
Submitted: Tuesday, Jan 31, 2006 at 13:36
Member - Howard (ACT)
Last 2 trips have seen the Fuel
Tank warning light glow on the petrol GXL.
first was in the
Vic high Country at Xmas and then again last weekend at Yadboro.
Both times I was under 1/4
tank full in main
tank but low fuel light had not come on.
Problem is that when this Fuel
Tank warning light is on you cannot pump from secondary
tank to main.
I know there is a float to prevent overfilling main
tank and assume this is sticking when vehicle is at steep angle for extended periods.
I can get rid if the warning light by removing and replacing fuse but the first time couldnt get pump to work until I had completely refilled main
tank then ran it down again.
last weekend I put in 20 litres drove around for 1/2 hour and light just reset after stopping on a slight uphill and then reversing.
what the hell?
Vehicle has 375K plus and I thought maybe there is wear on float pivot pins or something. However as I have never delved inside the fuel
tank would appreciati if someone out there who has can tell me how it all is supposed to work.
need to start somewhere.
Howard
Reply By: Member - DOZER- Wednesday, Feb 01, 2006 at 08:25
In the main
tank, seperate to the fuel gauge float and low level, is a pair of floats that tell the fuel pump cpu when the main is below 3/4 and when it is above.
Below, it allows pumping until low level in aux is set off, or it reaches upper 3/4 on main
tank.
So u have three earth signals that might be intermittantly on when they shouldnt.....the other thing it could be is an over current on the pump motor, there is a small filter on the inlet of the pump in the solenoid that cuts fuel backflow...i would start there....and give it a clean.
Other floats need the tanks out.
152223
Follow Up By: Member - Howard (ACT) - Wednesday, Feb 01, 2006 at 12:57
Andrew,
thanks for that, will start with the filter.
Howard
405912
