Site Search
Section Image
Tyre compressors
Submitted: Wednesday, Feb 01, 2006 at 22:20
Member - Michael
I've got a Blue Tongue Mark 4 tyre compressor and have been quite happy with its performance, that is until last week when I tried to reseat a tubeless tire on the rim, it just didn't happen even when I removed the valve assy from the valve stem. The compressor is at the most 2yrs old. Has anyone else struck this problem?
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Advertisement
ThreadID: 30338 Replies: 12
Views: 1229 FollowUps: None
AnswerID: 152404   Submitted: Wednesday, Feb 01, 2006 at 22:33
Member - George (WA) replied:
You need an initial large volume of air to get a tubeless tyre to seal on the rim. I don't think the blue tonque can do that, OK once the tyre has sealed
SW of WA
Click Image to Enlarge
Lets go
VKS-737, Mobile 2131
Reply 1 of 12
AnswerID: 152408   Submitted: Wednesday, Feb 01, 2006 at 22:41
Member - Ray replied:
Michael,
have you tried the inflated bike tube around the rim trick?
Reply 2 of 12
AnswerID: 152416   Submitted: Wednesday, Feb 01, 2006 at 23:41
BenSpoon replied:
I have managed to get by twice now by seating one side of the bead then using a fat ratchet strap and tightening it around the circumference of the tyre tread which makes the other bead bulge out onto the rim. Alot of patience needed, but it has worked for me.
Another option is getting a compressed air resivoir of some sort on the bluetongue- Charge that then use the stored air to seat the bead.
That said, why not make an adaptor so you can use your spare or another tyre to do the job? You may have to take the valve stem out of your already inflated tyre to get sufficient flow, but its not as though you will have to reseat the bead on the second tyre if it deflates completely.
Dolphin: The other white meat
Reply 3 of 12
AnswerID: 152417   Submitted: Wednesday, Feb 01, 2006 at 23:56
D-Jack replied:
My blue tongue III seats my beads no problems at all. I think though maybe the condition of the bead/size of tyre compared to rim makes a difference. I haven't needed to use anthing except a rubber mallet to just belt the tyre a bit to position the bead propertly until it seats while the compressor is going. Mine are 245/75/16s pm a 7 inch rim. If the rim is on the largish size compared to the tyre (eg if I had 8 inch rims) it might be a different story.
D-Jack
Reply 4 of 12
Activities Index
Coral Sea Island Sailing - Low Isles Coral Sea Island Sailing - Low Isles
Cairns and Tropical North QLD - QLD
Experience the Great Barrier Reef on board our luxury 30 metre sailing catamaran.
Abseiling - Half Day Abseiling - Half Day
Blue Mountains - NSW
Join us for a session of adventure and learn the "ropes" of abseiling.
Wine, Cheese, Chocolate, Champagne Safari Wine, Cheese, Chocolate, Champagne Safari
Hunter Valley - NSW
Enjoy a day of indulgence in the picturesque Hunter Valley.
Circus Workshop & Overnight Stay For 2 Circus Workshop & Overnight Stay For 2
Sunshine Coast - QLD
Learn how to fly on the trapeze, bungee-trampoline and juggle balls, diablos and devil-sticks!
Book Now - Things To Do
AnswerID: 152449   Submitted: Thursday, Feb 02, 2006 at 07:54
glenno(qld) replied:
I read in an old jack absalom book where he would pump the spare up to 80 psi and somehow use the air in that to reseat the tyre.
Reply 5 of 12
AnswerID: 152486   Submitted: Thursday, Feb 02, 2006 at 10:21
Kiwi Kia replied:
Now who was it that recently argued against using tubes in tubeless tyres ? It is sometimes easier to put a tube in then re-bead a tyre when off road. At least it will get you home.
Reply 6 of 12
AnswerID: 152503   Submitted: Thursday, Feb 02, 2006 at 12:03
Peter Guy replied:
Use a tube - easy!!!
Reply 7 of 12
AnswerID: 152504   Submitted: Thursday, Feb 02, 2006 at 12:05
HUGGY (SA) replied:
Hi Michael,
I can empathise with you. I originally bought the ARB tyre pliers. Hoever before I had a chance to use them I went to the 4wd show in Adelaide and saw a demonstration on a different brand. The demonstrator made it look so easy that I quickly got a refund on the ARB brand and purchased the new bead braker.
In all fairness the new beadbraker worked beautifully in breaking the rim, taking the tubeless tyre off the rim and popping it back on. This is where the fun starts.
My ARB air compressor would not make a dent on blowing up the tyre. Air flowed out quicker than it was pumped in. I bounced the tyre and did a few other little tricks with no luck. I took it to a service station and tried their high pressure pump. Still no luck. I then took it to a tyre repair place and he had no problem with pumping it up. His pressure was obviously sufficient to do the job.
We rang the helpline where we purchased the beadbreaker from and was told our ARB $400 compressor probably won't have enough grunt to do the job. They suggested you use a mixture container lux flakes (thick paste) to help seal the bead then try and pump it up.
Considering I am doing the Simpson in May I think its imperative to sort out this problem before I leave. Will probably simply add a tube if I have any problems on the way.
I LOVE THIS STUFF....
Reply 8 of 12
AnswerID: 152549   Submitted: Thursday, Feb 02, 2006 at 16:19
macy replied:
Go to an industrial or agricultural tyre fitter and get a scoop of the thick stuff they use it will hold air in a big gap and the small air comps. will easly manage.
Take a air tight container with you and they will probably fill it for a six pack!
Reply 9 of 12
AnswerID: 152555   Submitted: Thursday, Feb 02, 2006 at 17:13
Crackles replied:
Quickest way to reseat a bead is to remove the valve stem all together, run a quick squirt of lighter fluid around the bead of the tyre so the fumes drop inside, then light it. The small explosition expands the air & seats the bead. Don't try it with the valve stem in as it can pump the tyre up to 150psi+
Alternatively use your bull bar tube as an air tank so you can pump it up to 100psi+ to get the big rush of air, soap up the bead of the tyre & let it go. Ideally you'll need a 6cfm compressor or bigger to get enough volume of air otherwise.
Cheers Craig.........
Reply 10 of 12
AnswerID: 152613   Submitted: Thursday, Feb 02, 2006 at 21:11
Witchdoctor replied:
I am running a CO2 inflation system its output is 31 CFM at 250 PSI.
Will reseat both beads on a 35" muddie in 10 sec also run all you air tools.
Reply 11 of 12
AnswerID: 152617   Submitted: Thursday, Feb 02, 2006 at 21:24
Member - Phil G (SA) replied:
There are many tricks to getting beads reseated. I use a spare tyre inflated to 80psi to give a whoosh of air, but usually find that tyres on 8 inch wide rims are the difficult ones.
IMO prevention is best. Why anyone bothers to repair tubeless punctures by taking a tyre off a rim is beyond me. Instead, we've been using plug kits for the past 6 years - simple and no sweat - just use a plug kit with the tyre on the vehicle, and drive away 5 minutes later. When you reach civilisation, then get a tyre man to do the hard work, and do it properly.
I've also noticed that more people on the forum are discovering that lower pressures in tubeless tyres and lower speed means less punctures offroad.
Yes, I also carry a spare tube in case all else fails :-))
Mt Finke
LandCruiser HDJ79
Reply 12 of 12
Activities Index
Master Barista Course - Sydney Master Barista Course - Sydney
Sydney - NSW
This master coffee course will turn you into a true barista.
Traditional Thai massage - One Hour Traditional Thai massage - One Hour
Sydney - NSW
Experience rejuvenation throughout your entire body with a traditional Thai massage.
Drive a Lotus Elise 2003 for a day or Weekend Drive a Lotus Elise 2003 for a day or Weekend
Sydney - NSW
See the sights of Sydney, one of the world's most beautiful cities in your very own Lotus Elise 2003
