Petrol Hilux Tyres
Submitted: Thursday, Feb 02, 2006 at 12:21
BBails
Does anyone have a Petrol Hilux 2003 2.7.
Mine doesnt seem to have a tyre plaquard - Im curious what is legal for it. I currently have 31 * 10.5 R15 tyres on it - yes I know this isnt strictly legal. It seems to have a hard time pushing them on Sand (eg
stockton) - what do other people run on there hilux and how does it perform?
B
Reply By: ImEasy - Thursday, Feb 02, 2006 at 12:23
I ran the same size as you on Stokton, at around 12psi, no problem at all, diesel as
152495
Follow Up By: BBails - Thursday, Feb 02, 2006 at 12:29
I was running 15, maybe I should go a bit lower - It was at the south end (lavis lane) a couple of weeks ago, I really had to flog it to get it over the dunes, kept feeling like it was going to stall. Some times I thought it would bog and had to reverse up and get a faster run up. Car is fine on road, no lack of power.
406221
Reply By: AndrewW - Thursday, Feb 02, 2006 at 13:01
I have a 2002 3.4 V6 Hilux.
I run the 31x10.5x15 tyres too. It does sap the power a bit.
Mine is an SR5, so it can standard with 255/70R15 tyres. The equlivent size is basically a 30x9.5x15. This will give you a slightly wider tyre than the standard cheese cutters, but the diameter is the same. Being smaller than the 31" tyre, will give you some more power, but be about 4-5km slower on the highway when the speedo is reading 100kmh.
Also, pressures are important for sand. I ran 20psi on Fraser, and that was fine, and about the same across the Simpson. In both cases, the sand was very firm, as it had been raining recently. I actually went down to 12psi on Big Red, to get over the hard track.
152501
Follow Up By: BBails - Thursday, Feb 02, 2006 at 13:09
Thanks for that,
mine is a standard dual cab.
FYI - I checked the speed on
mine with a GPS and with the 31 tyres the speedo is bang on - ie 100Km = 100km. Im thinking I might try 30 * 9.5 next to lower the gearing a bit,
The 31s dont scrub but when I turn tight there is some clunking in the front end - Ive had a mechanic look at it all and Ive checked it out myself cant work out what it is - hoping smaller tyres might sort it out too.
B
406226
Follow Up By: simple - Friday, Feb 03, 2006 at 08:36
i had 255/70r16 on
mine and they were great, went fine on
stockton too.
they did scrub the guard on the left side at full lock but it was fine.
406394
Reply By: Member - Phil G (SA) - Thursday, Feb 02, 2006 at 22:12
I think you'll find that the 205R16 on split rims were standard.
152614
Follow Up By: AndrewW - Friday, Feb 03, 2006 at 11:02
Mine is the SR5, which was standard with 255/70R15. The 205R16 I believe is the stardard size for the standard model.
I was lead to believe that the 30x9.5x15 was a very similar diameter to both of these tyres. My experience is with the 255/70R16 tyres, and the 30" tyre falls within the 15mm oversize regulation of this tyre.
406422
Reply By: TUFF IFS LUX - Friday, Feb 03, 2006 at 20:47
g'day digger,
my 2003 hilux v6 has a 2" or so lift and I run 265/65x16 BFG A/Ts. That's the equivalent of 32.4x11.1x16 remembering from the top of my head. That put me speedo out by 9% so when my speedo showed 100kph I was actually going 109kph. I fixed this buy purchasing and fitting a programmable speedo ratio box from Marks Adaptors. Was about 160 bux and it's money
well spent coz you got 2 different setting which you can set 1 up for your smaller road tyres and then flick the switch and have a setting for larger mud-terrains, and the speedo will still be fine.
When this set of tyres wears out will look into a 2" body lift and a set of 285/75x16 which is 33.4x12.3x16. Should look tuff.
TUFF_IFS_LUX
152818
