FollowupID: 406395 Submitted:
Friday, Feb 03, 2006 at 07:37
Member No 1 posted:
des, in hot
weather even a window rattler shouldnt freeze up...and i dont car how old it is....the temperature of the refrigerant should be well above freezing point. sounds like there is something wrong Des
In
cold ..and i mean during winter
cold...generally below 5c but may happen at around 8-10c the outdoor coil may begin to make frost and this could eventually cover all the outdoor coil reducing its ability (efficiency if you like) to pick up heat from the outside and deliver it to inside. When this happens, controls or sensors tells the aircon to do a de-
ice...ie go onto cooling mode to defrost the outdoor coil so it can pick up heat...this cycle is usually only for a few minutes at most......
So des I think u have mis-interpreted what he said and have been wrongly applying it to the cooling cylce rather than the heating cycle
 Click Image to Enlarge |
| Make love, not war....Hell, do both...GET MARRIED!
