FollowupID: 406944 Submitted:
Sunday, Feb 05, 2006 at 07:54
Member - David 0 posted:
Are the wheels not part of the drivetrain?
The only difference between this handbrake setup and a handbrake acting at the wheel is it is acting ahead of the rear differential. Tell me how that makes any difference if your handbrake in the later scenario is adjusted correctly ie acting equally on both wheels.
Don't disagree with Robs comment about assessing first and agree with keep is simple- however the hand brake technique in the auto Nissan is very affective if you have been silly enough to get yourself in that position.
Regardless of whether you beleive it is actian EQUALLY on all four wheels or not, it is still more effective for two reasons.
1. The footbrake doesn't act EQUALLY on all four wheels it is quite biased to the front. In a steep reverse descent without engine braking this means most of the braking effort is acting on the front wheels- the ones with the least grip. With engine braking no big deal without it- interesting to say the least.
2. In addition to the weight acting on the rear wheels, any force resisting the turning of the rear wheels (and the handbrake does this more effectively regardless of its location) results in a weight shift to the rear further enhancing the grip at the rear. Vica verca, any application of footbrake is much less effective at shifting the weight becasue it doesn't act as effectively on the rear wheels.
The moderation is still done with the footbrake and this is what deals with the varying grip. It works well but like all thsese things, knowledge is one thing, application of the knowledge (skill) is another.
If I was in Rob's position I wouldn't teach it, but it works and works well if you have the skill (though practice) to use it.
Dave O
 | A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do.
