AnswerID: 152806 Submitted: Friday, Feb 03, 2006 at 18:27
VK3CAT
replied:
Hi Rosy. Not sure on your projecta regulator but if it is similar to the 20 amp unit from Jaycar Cat MP-3126 which has a similar LED indicator, then this is how it works.
With both battery & panel connected, the amber LED will show. This will remain until the battery voltage is about 14.5 volts. At this stage the green LED will show until the battery voltage drops to below 13 volts.
Thus, it is possible that your battery voltage in the mornings is still too high for the regulator to kick in. (Try loading the battery to drop the battery volts & see if the regulator switches over!)
The claimed wattage of solar panels is very misleading. Solar panels calculate the wattage by multiplying the Load voltage (typically around 17 volts for a 12 volt system) by the load current
I would have thought that a 5 amp regulator is a bit on the small side for a 65 watt panel (I=P/V) =65/17 = 3.8 amps.
Also, with only a 65 watt panel, it is probably not necessary to use a regulator at all. The loading on the
fridge should be adequate to regulate the load.(Ensure that you have blocking diodes fitted or you will get a flat battery.
Example: My Engel
draws 3.3 amps at 12.6 volts. On thermostat position 1 with an ambient temperature of 25 degrees it has a run/standby ratio of 1:3.25, position 1.5, 1:2.67, position 2, 1:2.
My two 55 watt panels produce a maximum of 3.2 amps but I will rarely get 6.4 amps of charge unless I am monitoring there position & angle.
It is only in perfect conditions that you will get a full 65 watts out of the panel & the panel should be pointed towards the equator an an angle 15 degrees greater than your latitude. (This is a general set & forget setting)
All cables and connections should be of the lowest resistance - ie short thich cables & quality connectors. Keeping a volt meter connected to monitor the battery volts is the best way to see how your system is working.
Cheers Tony.
Reply 3 of 6
