AnswerID: 152849 Submitted: Friday, Feb 03, 2006 at 22:59
Mainey (WA)
replied:
Steve,
I have asked the same question, post #30150, "Bifacial (double sided) SOLAR Panels"
I’ve recently been in contact their Australian agent and after talking with him have decided to stay away from them, only as the panel is specifically designed to be used with-in the limited parameters specified by the manufacturers, which definitely does prohibit them being used on a vehicle roof, as I require.
As to the quality aspect I don’t have an opinion.
I’ve come upon a panel called “Sunpower” which is an American designed and specified product they have made in China, which has my attention presently, as they will have a new 110 watt panel on the market shortly, and I’ve my name down for one at the moment.
The presently available 90 Watt panel specs are mighty impressive as they have an exceptional low light performance, which will maximise the daily power available and they have a far lower temperature coefficient, giving a very superior performance at the usual high panel temperatures encountered when the panel is sitting in the sun 24/7 in the far north.
They have a cell efficiency of ~21% which is at least 25% better than most solar panels I’ve seen, as most are rated at between 12% and 15%.
The 90 watt panel uses a 4mm thick ‘glass’ surface layer, whereby most use only 3mm and is only 1,038mm x 525mm, 7.4 Kg and putting out 5.1 amps, which equates to ~$8.90 per watt, where the budget priced Suntech panel puts out only 4.65 amps is physically larger and heavier at 1,195mm x 541mm, 8 Kg and is only 80 watts, and about ~$8.70 per watt, and without any of the high temperature and low light benefits available to it, so to me is no real comparison, I prefer to spend the extra 20 cents per watt for the additional benefits available from the Sunpower panel, as their "
technical specifications" surpass even the Sharp or Kyocera panels.
Reply 7 of 10
