AnswerID: 152879 Submitted: Saturday, Feb 04, 2006 at 08:02
Big Woody
replied:
Hi Kaymar,
I think you may have to explore further for the problem as I have had an 80 series 4.5 litre Dual Fual and my brother and dad both have 100 series on gas. They all have had Safari snorkels fitted and the cars have never stalled or had any issue whatsoever.
I have got no idea what the problem might be in your case but the "gassy's" diagnosis seems a bit far fetched to me.
One thought may be to explore a different chip for the computer to suit LPG or Dual fuel application.
It seems more like a mixture or a sensor problem to me. Maybe the "gassy" has played with one of the sensors like the air flow meter or oxygen sensor. Also LPG will usually idle slower than petrol so it is normal to have to bump up the idle revs a bit to suit the LPG. They will just be a little bit high on petrol thats all but only by a 100 rpm or so.
My brother and my best mate are both licensed gas fitters in Qld and NSW so I will run this by them and see what they come up with and get back to you.
Brett
Reply 3 of 6
FollowupID: 406692 Submitted:
Saturday, Feb 04, 2006 at 09:02
gqpat posted:
Depending on the gas system your using will have a diff effect i'll explain Impco systems use a variable venturi so if you get a gush of air down the
snorkel it will move the mixer and alter the gas accordingly and nyou may not have a problem But if it is a simple mixure design (fixed hole size ) OMVL,LOVATO, SPRINT GAS etc it has no compensation for this resulting in a lean mixture when you get the extra air ,you can however run a Balance Line from you
snorkel to the rear side of the converter this will apply pressure to the converter diaphram and richen the mixture up when you get the forced air in .You will just need to toy around with the location of the hose in the
snorkel to get it to work resonable as you may get over enrichment good luck..
FollowUp 1 of 2
FollowupID: 406901 Submitted:
Saturday, Feb 04, 2006 at 21:29
kaymar posted:
Hey Brett, i would appreciate any advice from your rellos, the other guys are quite right about the balance hose, however the gas fitter i have spoken to claims due to the width of the 100 series the hose has to run to far and as a result the balance hose won't work, fact or fiction i dont know. Any advice on upgrading the chip would also be appreciated. The system installed in my vehicle is the dual tank torpedo system.
Thanks K
FollowUp 2 of 2
