Blocked Catalytic Converter
Submitted: Sunday, Feb 05, 2006 at 13:08
ThreadID: 30443 Views:4836 Replies:3 FollowUps:6
I drive a GU II 4.5 L dual fuel Patrol and recently towing my 2.3T van up long steep hills e.g. Mt. Ousley south of Sydney, it was like I had the brake on - down to 1500 revs and 10 kph in first!!
Nissan found that it was a blocked catalytic converter in the emission control system - and once replaced, Mt. Ousley going home was no problem at all.
The Patrol has done 110 K Km, approx. 30 K Km on dual fuel, using ULP after every 3rd or 4th tank of gas.
Can anyone tell me, please, what causes the blockage and how to avoid it in future. The replacement converter cost me $500 plus $170 for trouble shooting!!
Thanks for your help.
Pete
Reply By: 120scruiser - Sunday, Feb 05, 2006 at 13:20
Hi A Peter
We come across a few every now and again but mostly on older cars.
Usually when the engine is worn and using oil or blowing smoke can cause them to break down or if you use leaded fuel they won't last long. Obviously you didn't use the second as you can't buy it any more.
Do you use good quality fuel?
I have had the odd one just melt down and I couldn't honestly say why.
We have had alot of bad fuel over the past 2 years which have contributed to lots of expensive dramas for customers. I can't stress how important it is to buy good quality fuel.
Sorry I'm not much help.
120scruiser
AnswerID: 153122
Follow Up By: Member - Bill S (NSW) - Sunday, Feb 05, 2006 at 19:09
HI ,I can tell you how to eliminate this ever happening again but unfortunatly can not due to the absolute disbelief of members and their derogative remarks. So Peter have a look at the add that appears on the right side of this forum and whey it up fo yourself.www.fitchcatalyst.com.au . Never change an exhaust catalyst again.
This was submitted by a user of the product not BILLS and I might add a happy user.
FollowupID: 407093
Follow Up By: Leroy - Sunday, Feb 05, 2006 at 22:09
My clutch needs replacing every 150k km's. Do you think a fuctch could extend the interval to 750k km's?
Leroy
PS. what can't a fitch do?
FollowupID: 407132
Follow Up By: theshadows - Sunday, Feb 05, 2006 at 22:23
Bill S are surgesting that fitting a Fitch makes it legal to tamper or remove a cat?
Or a Fitch will stop a cat destroying it self if a Lamda sensor dies??
Bill S Ive tired for five minutes to come with with this in a nice polite manner ... here goes
You continue to flaunt the forum rules with blatant self advertising. You continue to mis advertise your product. I will consider If I should forward this and all other advertising for your product to the deptment of consumer affairs. Have a nice day.
shadow
FollowupID: 407137
Follow Up By: Truckster (Vic) - Monday, Feb 06, 2006 at 00:45
Come on theshadows.. you know that "THAT DEVICE" will fix everything on earth... Including poverty in 4th world countries and AIDS in Africa.
FollowupID: 407173
PS. Consumer affairs are as toothless as the ACCC... nobody is really scared by them!
FollowupID: 407174
Follow Up By: tex1972 - Tuesday, Feb 07, 2006 at 20:47
thats right I fitted one of these to my circulatory system and have managed to remove all the blood from my alcohol system
FollowupID: 407602
Reply By: Billowaggi - Monday, Feb 06, 2006 at 00:35
Cat can be damaged by a crook spark plug or HT lead particularly critical when running on gas, high tension electics must be in good order.
Regards Ken.
AnswerID: 153248
Reply By: A. Peter Read - Tuesday, Feb 07, 2006 at 10:33
Hi Everyone,
Thank you for your informative and "interesting" replies.
Pete
AnswerID: 153568
