Piranha MkIII Battery Monitor
Submitted: Sunday, Feb 05, 2006 at 14:37
Member - Corey K (VIC)
Hi there,
Does anyone have a wiring diagram for the Piranha MkIII Battery Monitor, for connecting to the DBE 180S isolator.
Regards,
Corey.
Reply By: brom - Sunday, Feb 05, 2006 at 20:41
hi corey
dont know if this will help...have u tried www.fridge & solar .com(email VAL) or TJM . com they do have basic diagrams for wiring having said that im in the market myself 4 a duel battery system for my hilux so have been looking myself...hopes this helps regards brom.
153198
Reply By: Sand Man (SA) - Monday, Feb 06, 2006 at 02:46
Corey,
Check out the following Web Site for information and diagram for your DBE 180S.
The small wires on the right hand side of the unit go to the monitor. Red=positive (active) Black=negative(earth return)
TJM are distributors of the Piranha product range and I am sure will help if you still need it.
Click Here
153255
Follow Up By: Sand Man (SA) - Monday, Feb 06, 2006 at 02:52
But wait, there's more!
On the left side of the page displayed when you "Click Here", you will see the heading "Manuals". Click on this and you will then see "Battery Monitor Model DBM3 Fitting Instructions.pdf". Hopefully this will give you what you are after.
407186
Reply By: scottp - Monday, Feb 06, 2006 at 18:47
I have the db180S+ Which is the db 180S with a mkII monitor
The monitor connection should be the same.
The instructions read that on the larger of the two plugs (the one with four wire connectors) Reading from left to right as looking at the plug with screws showing (left being number one)
1=black
2=white and
orange
3=red
4= nil
Let me know how you go!
153407
Reply By: Member - Corey K (VIC) - Monday, Feb 06, 2006 at 20:17
Thanks everyone for your assistance.
Scottp, your instructions work perfect.
Regards,
Corey.
153431
