gme tx 4200 no manual what does it do
Submitted: Tuesday, Feb 07, 2006 at 21:37
Member - laura B (NSW)
can anyone tell me what this stands for on tx 4200 ( -EE-- ) does it mean an error also can does someone have a manual so understand what the function are for this radio if they could email it it would be great
Reply By: Truckster (Vic) - Tuesday, Feb 07, 2006 at 21:43
have you tried the GME site?
153726
Reply By: Haza - Tuesday, Feb 07, 2006 at 21:55
don't know if this helps
Eprom Error
goto to post 18190
153729
Follow Up By: Member - laura B (NSW) - Tuesday, Feb 07, 2006 at 22:13
so by the sound of it its had a surge through it......thanks.....
Laura B
HAPPY INSIDE WHEN IM OUTSIDE
407639
Reply By: Scubaroo - Tuesday, Feb 07, 2006 at 22:17
Download the manual at GME website
153736
Reply By: Michael Carey - Tuesday, Feb 07, 2006 at 22:22
It usually means the EEPROM chip in the radio (stores all the info like memory channels for scan etc.) is corrupted/damaged. From experience,in most cases the radio will work OK but will not "remember" anything eg. last channel, scan/quiet memories.
But in extreme cases I have seen weird things like channels in hexadecimal with letters A to E, more than 40 channels etc.
You could probably get it fixed, it's a fiddly job as the chip is a surface mount type, and then it will need to be programmed with the TX4200 software. But in the end, you still end up with an old radio, best put a little more money together to buy a new one.
153738
Reply By: VK3CAT - Wednesday, Feb 08, 2006 at 07:52
I believe that the TX4200, like the TX4000 is programmed via the microphone socket. On My TX4000 you can get all this weird stuf by shorting certain michrophone socket pins - can also get a channel 25kHz below channel 1.
Just a thought, the microphone plug or cable may be faulty so remove it then re-power up the unit.
Cheers, Tony.
153783
