Wind noise on 100 series
Submitted: Wednesday, Feb 08, 2006 at 20:54
viz
Evenin' all...
Trying to solve a wind nose problem in my LC100 - very very noisy inside with the front windows open. Reduced if the rears are opened a little and/or the sunroof cracked open. Seems to be part generated by the seatbelt where it goes down the side of the B pillar.
I have bought a genuine Toymota window shield for the drivers side, but I note that it seems to be the bikini type (does not go all the way down the front of the window), yet there are others that are bigger and go all the way to the bottom of the window.
Anyone had any experience with these things - which is better???
Better still - how does one get rid of the wind noise???
TIA
/viz
Reply By: viz - Wednesday, Feb 08, 2006 at 20:56
Ooops wotch the spelling boy wotch the spelling...!
Tying to solve a wind NOISE problem in my LC100... :)
/viz
153935
Reply By: 100TD - Wednesday, Feb 08, 2006 at 21:28
i have the aunger ones on
mine and it is still noisy.have
snorkel also but was still noisy prior to this.i think it is the shape/aerodynamics of it that causes it.Paul
153948
Reply By: Wizard1 - Thursday, Feb 09, 2006 at 08:46
I would suggest you don't open the window!
154010
Follow Up By: viz - Thursday, Feb 09, 2006 at 12:35
Yeah
well it has come down to that. In the days when I had hair I loved the window down (wind in hair thing, you know). I would still like to have the window down to remember those days, even if it means buying a toupee...
/viz
407966
Reply By: Member No 1- Thursday, Feb 09, 2006 at 17:44
i run the slim line ones...about 50mm
dont like the full shields
works ok for me...a lot less noise
i used to put them on the 80's also but back them i couldnt get slimline ones so i cut the normal ones down on a band saw...worked a treat.
154114
Follow Up By: viz - Thursday, Feb 09, 2006 at 19:26
OK sounds good - the slime line ones are from Toyota?
/viz
408069
Follow Up By: Member No 1- Thursday, Feb 09, 2006 at 20:51
thats where I got both stes last time....northpoint toyota in SA
i have no idea if they are toyota accessories or aftermarket stuff but
408083
