Dust in spare wheel locks
Submitted: Wednesday, Feb 08, 2006 at 20:58
Dave198
Just looking at previous posts and saw a photo of the adventure camper stone guard. Also noticed in the photo a very clean nissan spare wheel with a lock attached. I think the key may have been in the lock, and wondered how everybody keeps the dust out of their locks. If its full of dust, its blo------ hard to get the spare wheel off when you need it.
I use a small piece of bicycle tube looped through the Yale type lock and covering the keyhole.
It works
well for me, I can always open the locks, and most of my work is on outback roads.
Reply By: RustyHelen - Wednesday, Feb 08, 2006 at 21:14
Great question and I look forward to some suggestions. Our first biggish trip last year and at some point I had to unlock the shovel/axe holder and thought for quite a while that I was in trouble. Trusty spray can came out and eventually I "dissolved" all the stuff and could unlock it but realise this is a very ordinary method.
Rusty
153941
Reply By: JW - Wednesday, Feb 08, 2006 at 21:27
Dave,
I found a Taipan brand padlock at a local (
Yeppoon QLD) auto
shop. They are fully rubber coated and have a dust cap over the key hole. They have a long shank which makes it suitable for locking the spare. After many dusty trips, have not yet had a problem with inserting the key. This was preferrable to taking out a second mortgage to buy a locking nut from Nissan.
regards.
Jon W
153945
Reply By: Member - Roachie (SA) - Wednesday, Feb 08, 2006 at 21:28
I usually fill the key hole with vasaline or similar. It stops dust and
water getting in and makes it easy to slide key in when it's needed.
Roachie
153947
Reply By: Member - Paul P (Bris) - Wednesday, Feb 08, 2006 at 21:44
I use masking tape over the key entry area on my locks. Works fine and is cheap. If the dust gets in I flush with WD40 or similiar.
Paul
153954
Follow Up By: Waynepd (NSW) - Thursday, Feb 09, 2006 at 17:32
Yeh me too Just a bit of duct tape wrapped around it seems the go. Had no problem yet
408043
Reply By: hoyks - Wednesday, Feb 08, 2006 at 21:49
Bike inner tube works for me. Cut a 1" wide ring out of the tube. Works
well and is cheap.
153955
Reply By: Shaker - Wednesday, Feb 08, 2006 at 22:57
I stuck a piece if 10mm self adhesive sealing foam trimmed to the shape of the bottom of the lock, with a small razor cut over the keyhole, after 2 outback trips & heaps of high country, lock works perfectly.
153971
Follow Up By: Skid - Wednesday, Feb 08, 2006 at 23:28
I use those black rubber door stops found in bunnings over my padlocks, come in couple of sizes - take your locks in and size them up.
Works brilliantly for me for a number of years
407876
Reply By: GaryInOz (Vic) - Wednesday, Feb 08, 2006 at 23:42
102 uses for a condom.....
153981
Follow Up By: madcow - Thursday, Feb 09, 2006 at 08:41
407920
Reply By: Member - Oldplodder (QLD) - Thursday, Feb 09, 2006 at 08:48
I just take the locks off before a trip.
Reckon I will be around the car most of the time.
Has any one actually lost anything on a trip with not using locks?
I have had the opposite experience, no I didn't gain anything :-), but I had a friend on a trip loose the key for the lock. Had to snap the stud off.
154011
Reply By: Johnnotoo - Thursday, Feb 09, 2006 at 14:16
A dab of silicon such as roof and gutter sealant works ok too. just don't force it down into the key hole!Puulls off easy when you need it (not too often I hope)
johnnotoo
154082
Reply By: Fusion - Friday, Feb 10, 2006 at 10:51
Hey that's my (not so clean anymore) wheel & lock. I've never even thought about dust filling up the keyhole, but with all these good suggestions I'll make sure I do something about it next time we get outback.
BTW - when that photo was taken the car was only about a month old :)
Thanks,
Aaron.
154269
