Good morning all,
Submitted: Saturday, Feb 11, 2006 at 10:18
ThreadID: 30672 Views:2030 Replies:3 FollowUps:1
Two questions, 1st how hard is it to change centre bearing in hilux (tailshaft) saw one on ebay starting at $35 brand new including bracket, have priced one from advance bearings at blacktown $87 do you think one would be better quality than the other, (no nothing about bearing quality).
2nd, can you engage low range without locking in front hubs, have been told this is a big no no but I have read of people on here doing so. Am I going to brake anything, handy when pulling boat out of water on slippery ramp save getting out and locking hubs in for the sake of a few metres.Allows me to put in that low range that I need.Thanks in advance Regards Steve
Reply By: Member - Tony G (ACT) - Saturday, Feb 11, 2006 at 15:13
Changing the centre bearing is a very easy job. Low range can be engaged with hubs out, BUT only for what you say of backing a trailer up a steep drive.
AnswerID: 154450
Reply By: Sarg - Saturday, Feb 11, 2006 at 18:20
Q1 :Isn't hard at all. Just make sure that you mark each component in relation to the next ,so that it all goes back in original alignment.
Try here for a better price;Cost me $69 + Johnny Howard in Oct.
NEW SOUTH WALES
Don Kyatt Spare Parts
63 Powers Rd
Seven Hills NSW 2147
Ph: 02 9674 6911 Opening Hours: M - F 8.30 to 5pm
Fax: 02 9624 8114 Sat 8.00 to 12pm
Email: enquiries@terraintamer.com
Branch Manager: Terry Cheal
Q2: Yes you can, but I would think that a couple of extra steps towards the front of your vehicle & engaging your hubs before you launch/retrieve your boat wouldn't be too hard, and make the whole operation easier,quicker & safer.
If it is ,then best you leave the centre bearing alone.
AnswerID: 154467
Follow Up By: Member - Stephen M (NSW) - Sunday, Feb 12, 2006 at 10:50
Thanks Sarg will try out Don Kyatt, I'm omly located at Penrith so will give them a ring. Regards Steve M
FollowupID: 408486
Reply By: PatNav - Thursday, Mar 02, 2006 at 23:38
Hi there Stephen Q1 the centre bearing is a piece of cake to change just mark your tail shafts befor you unbolt them so you dont though them out of balance from origanal unbolt the bearing housing you may need to press the bearing off but a gental tap should get the new on 1 oh and also mark position of the sharft going into gear box befor you take that off to good luck
Q2 you would be better off locking in ya hubs befor you pull boat out as you will have to get out later an tie boat down so why noy risk it in the 1st place unless you a lazy ass an get others to tie boat down in that case get them to lock hubs in an out 4 you too ha ha ha....
catch ya
AnswerID: 158239
