hilux please help
Submitted: Sunday, Feb 12, 2006 at 07:57
boating
Hi im new to this site and from wa ive seen it looks very helpfull
I live in NZ and own 1999 hilux with 5l 3lt 4x4 and looking to fit a turbo from 2.4 surf to it. Can any one help with tips etc and has anyone got the same thing.
I have heard different things regarding where the oil return has to go and engine
may over heat on this model any help would be great
thanks
steve
Reply By: 46lux - Sunday, Feb 12, 2006 at 08:50
G'day Steve
If you can afford it put a after market turbo on. It will be so much easier in the long run i have a ct 20 on my 3l and there is bit of work involed, you have to put the oil return line into the top of the sump get custom oil lines made it, get the EIF part of the air inlet modified, new exhust, silcone hoses, and get your fuel pump tune for the turbo. so at the end of the day you will only save about $100
so go after market
154519
Reply By: boating - Sunday, Feb 12, 2006 at 09:58
Hi thanks for info i heard you cant get sump off without removing motor did you do that or have you another way
steve
154526
Reply By: 46lux - Monday, Feb 13, 2006 at 19:28
G'day steve,
yeah you can take the sump off without removing the motor drop the oil out and remove all the bolts and then the difficult bit is break the sump seal from the engine block once thats done you will need to weld in the drain above the oil level.
If you would like photo's please leave PM me.
154763
