Coil spring spacers
Submitted: Friday, Jan 24, 2003 at 16:54
ThreadID: 3079 Views:3544 Replies:3 FollowUps:0
Has anyone got or heard of coil spring spacers to gain lift with factory coils installed? Rancho sell them for $110 a pair for my Suzy Grand Vitara XL7.
Reply By: Truckster - Friday, Jan 24, 2003 at 17:37
They are usually used for levelling a car out...
EG:->> GU's all the weight is on driver side, aux tank, driver etc etc.. you put the 10mm spacers in the drivers side, to level the car up a little.
Not really just to gain lift, but I cant see why they wouldnt work.
Try ARB too, they sell them, as do TJM, probably anyone who makes suspension like Bilsteins, Koni etc...
AnswerID: 11815
Reply By: voxson - Friday, Jan 24, 2003 at 22:47
yep... i have used a pair of 30mm spacers on top of my springs on a gq patrol.
I had a 4" suspension lift then fitted a winch which dropped the nose a bit...
AnswerID: 11832
Reply By: Slunnie - Monday, Jan 27, 2003 at 00:15
Try a smaller retailer than Rancho. You will probably find the spacer was imported. I picked up 2x25mm spacers for $40 or $50 from North Shore 4WD or whatever they are called. They are just polyurethane rings that sit over the spring.
Slunnie
AnswerID: 11905
