Turbo Timer & Alarm
Submitted: Sunday, Jan 26, 2003 at 06:27
ThreadID: 3091 Views:1762 Replies:2 FollowUps:5
I am looking for Turbo timer & Alarm that would start up vehicle remotely while walking up to it (For a Land Cruiser). Any advice of what make & type to look out for? Cheers
Reply By: Truckster - Sunday, Jan 26, 2003 at 08:07
Why would you want an alarm that starts the car as you walk up to it?
just askin thats all.
Turbo Timer, check with your insurance company first, some wont allow them .
AnswerID: 11865
Follow Up By: Member - Cruiser1 - Sunday, Jan 26, 2003 at 20:43
'coz James Bond's got one, maybe? :)
FollowupID: 6794
Follow Up By: Wil - Monday, Jan 27, 2003 at 07:43
I guess it would be good to be able to give it a bit of time to warm up before putting load on. The Bond effect as well I guess...!)
FollowupID: 6797
Follow Up By: Truckster - Monday, Jan 27, 2003 at 20:26
Takes ages to open the door and put a key in and start it.....
FollowupID: 6833
Follow Up By: Frog - Thursday, Jan 30, 2003 at 09:58
What if your car is a manual one and is in gear. It would look pretty silly bobbing around the car park with the handbrake on and nobody in it :)
FollowupID: 7022
Follow Up By: Wil - Friday, Jan 31, 2003 at 06:23
No worries of cause. Mine is an auto 80 series TLC. What make of alarm is the most reliable for a 4WD with all the elements likely to be thrown at it?
FollowupID: 7085
Reply By: Matt M - Sunday, Jan 26, 2003 at 21:26
Yes you can get alarm systems that can be set up to start the car, only availble for an automatic car for obvious reasons!! I do think that they are illegal in most states though, going by memory. Not exactly sure why but a good installer would be able to give you a run down!
There are some top alarm systems out there that do incorporate a turbo timer in the system, negating the need for intergrating the alarm and T/timer together. Just a hint, some of the systems are also WATER PROOF!!!!! Ie the module and key remotes, could be embarrasing in a water crossing to get the system wet and shut down, ignition, fuel, doorlocks....could be very bad!
AnswerID: 11894
