Powerpole connectors for 12V accesories
Submitted: Saturday, Feb 18, 2006 at 21:09
Tim HJ61 (WA)
As a follow up to PostID 22559 from May 2005, regarding Anderson PowerPlug mini connectors, Scubaroo posted a reference to a RigRunner. Powerpole connectors are also the subject of a posting by Mike DiD PostID: 26778
Scubaroo said
***There's a powerboard-type beastie in the states called a RigRunner, with each set of POWERPOLEs individually fused with the appropriate-sized fuse for the accessory, that looks just the ticket for an evening knock-off project. Bung a 50A anderson on the input, and you've got 12V power on tap in the camp/tent, or even mounted in the back of the vehicle if it tickles your fancy. If I ever get around to it I will post pics. ****
Searching around for these things for myself, and figuring Scubaroo hadn't got around to posting a photo, I am.
I found a supplier of these at
http://www.qsradio.com/ and the RigRunner Panel photo is at www.qsradio.com/RIGrunnersl.jpg"
Not cheap, and requiring posting from the US, but pretty cool looking bits of gear.
Tim
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Feb 18, 2006 at 22:20
They do look the bit don't they. Like one of those old telephone switch boards once you connect 13 plugs to the 4012. Only a foot long though, I would like it to be at least 2 foot so I could lable it and not get confused (Excuse the pun !).
Keep it simple !
Regards Derek.
155772
Reply By: Member - Andy Q (VIC) - Sunday, Feb 19, 2006 at 00:05
G'day Tim, Yeah man they look the biz. Why not buy local, get your local Battery World or decent battery supplier to make you up a Powerpole. My local does them often.
andy
155781
Follow Up By: Tim HJ61 (WA) - Sunday, Feb 19, 2006 at 00:18
mightyQ,
Didn't know Battery World supplied them. The only references I've found have been Altronics and Jaycar.
Given they didn't know about the need to balance a pair of batteries before installing them in series for a 24v installation, and a few other times when I've had blank looks when trying to work through battery issues, I'd stopped going back. Good to hear you've had good service from them.
Tim
409772
Follow Up By: geocacher (djcache) - Sunday, Feb 19, 2006 at 00:24
Depends on the franchisee.
I know the
Geelong one is run by a qualified electronic tech, presuming it's still the same guy as had it a while back.
409773
Follow Up By: Member - Andy Q (VIC) - Sunday, Feb 19, 2006 at 12:17
G'day Tim, Chris the owner of the Battery World in my area (vic) makes them up to your specs. Maybe you could find yourself a decent auto elec and he/she could make a Power Pole to your specs....the hardware is readily available.
andy
409809
