trailer wiring
Submitted: Thursday, Feb 23, 2006 at 12:41
gordie
Can anyone advise me on my trailer wiring problem. I have successfully wired my car to my trailer using round trailer connectors and 5 wire core loom trailer wire. The problem is thast everything works as it should except for the right turn signal on the trailer. It lights up but does not flash.The left one works fine. Any ideas.
Reply By: Member JD- Thursday, Feb 23, 2006 at 12:51
Hi Gordie,
OK, alls ok with trailer off?..if so its probably an earth problem.just run a single from the earth on the trailer plug to the draw bar..a tek screw makes it easy..Hopefully this will help.
JD
156655
Follow Up By: oakey - Thursday, Feb 23, 2006 at 23:11
I agree, it's most likely to be an earth problem. If the brakes and tail lights etc work when they should and only that one indicator is not behaving then rewire the earth on that tailight and make sure it has a sound connection to the loom underneath the trailer.
410885
Reply By: Member - Coyote (SA) - Thursday, Feb 23, 2006 at 13:11
i had a similar problem when my trailer wire snapped after the trailer wasn't fastened properly.. I did a google search for trailer wiring and found several versions of 5 pin wiring.. it was quite a while ago now but I think I still have it at home.. I basically just tried each one until they all worked properly.. AI found that some of the configerations came close like you are talking about, but ended up with obscure thngs happening like you mention, eventually I find the right one (I think there was 4 versions) and all works fine now..
Not much help directly i know, but I'll check back this arvo when I get home and if no one has given you better advice I'll grab the print out I had when I fixed
mine and let you know the web address I go t it from. Good luck..
156662
Reply By: Pajman Pete (SA) - Thursday, Feb 23, 2006 at 13:30
Try Here
156665
