Draft ADR rumour
Submitted: Thursday, Feb 23, 2006 at 21:53
Member - Andrew W (SA)
I've been unable to confirm this with DOTARS as of today, but have been told by a consultant at a
suspension component manufacturer, that there is a current draft of ADR changes that will limit the increase in ride height from manufacturers specification to 50mm.
Is anyone familiar with this and how it gets translated into roadworthiness by the states?
Ciao for now
Andrew.
Reply By: Exploder - Thursday, Feb 23, 2006 at 22:04
I think the new Natonal laws are going to be 100 or 150mm Maximum overall increases that can be made up from Tyres (I think tyres are limited to 50mm taller than standard ,
suspension and body lift, no exceptions so you can’t be engineered for anything over this.
There are people on hear who a fall bottle on this stuff, I sure they will fill you in on the finer details of it all.
156767
Reply By: Truckster (Vic) - Thursday, Feb 23, 2006 at 22:38
This was discussed about 4-5 mths ago, try searching
156772
Follow Up By: Member - Andrew W (SA) - Thursday, Feb 23, 2006 at 22:56
tried. any other clues?
Clueless Andrew.
410880
Follow Up By: Truckster (Vic) - Thursday, Feb 23, 2006 at 23:45
Draft National Code of Practice for Light Vehicle Construction and Modification (NCOP)
http://www.dotars.gov.au/transreg/vsb/PDF/NCOP11%20Section%20LS%20Suspension%20and%20steering%2019sept2005.pdf
410897
Follow Up By: Member - Andrew W (SA) - Friday, Feb 24, 2006 at 00:20
thanks truckster.
The dotars site was not working earlier in the evening.
410911
Reply By: Richard - Friday, Feb 24, 2006 at 11:33
Quite a few submissions were put into the RTA by 9 December 2005 by various NSW groups. I understand they were sent to
Canberra. Word there will be some sort of response in March 2006. Not sure about other states.
156838
Follow Up By: Member - Andrew W (SA) - Friday, Feb 24, 2006 at 11:34
thanks Richard.
410972
Follow Up By: Member - Collyn R (WA) - Friday, Feb 24, 2006 at 11:46
I believe this is correct.
Collyn
410980
Follow Up By: Truckster (Vic) - Friday, Feb 24, 2006 at 11:51
Canberra
and probably filed in the bin instantly ;)
410982
