Prado rims and tyres?
Submitted: Saturday, Feb 25, 2006 at 22:01
jonboy
Hi All
Can a 265x75x16 fit on a 2000 model RV prado rim?
Reply By: 120scruiser - Sunday, Feb 26, 2006 at 16:03
Might be a bit wide for the 6 inch rim and may hang out the guard a bit as
157159
Reply By: prado4x4 - Monday, Feb 27, 2006 at 12:32
The 265/75R16 is too wide for the 6 inch rims on the RV. To fit those tyres you'll need the 7 inch wide rims of a GXL spec, etc. You will also need some flares as the wider tyres/
wheels will stick out the side.
Another option is to consider a narrower tyre (that will fit on the 6" rim), that has a higher aspect ratio to gain the increase in rolling diameter.
157285
Reply By: Surf - Monday, Feb 27, 2006 at 12:35
You'll have to upgrade to the 7 inch rims to fit 265 x 75 x 16.
90 series GXL steel rims are as rare as hens teeth, 16 x 7 inch aftermarket rims are not a run of the mill size so are a lot more expensive than the 15 x 7 and maybe even the 16 x 8 (not sure on that one).
All up its an expensive excercise moving to the larger tyres.
157287
