FollowupID: 412633 Submitted:
Thursday, Mar 02, 2006 at 23:10
pjchris posted:
My personal opinion on this is that this particular vehicle exists in a very wierd grey area.
The basic vehicle, Chassis, body
suspension, wheels
tyres etc are more than capable of handling the 3200kg limit of the manual transmission model. Then they take the manual out, insert an automatic, change nothing else, and you lose 700kg of towing capacity.
I think that Nissan lower the towing weight because the Auto transmission simply won't take the strain if you were to tow over 2500kg continuously. It's a reliability and warranty thing. Nothing to do with the rest of the vehicle. It's not going to run off the road, collapse the
suspension, cause tyre blowouts etc just because you put 2600kg on the back. It might break the transmission (And I stress the might) and this could cause an accident.
This is the only vehicle I know of that is in this situation.
And in my dealings, Insurance companies aren't all that bad either. They don't 'wipe you' if it's not your fault even if your vehicle is technically unroadworthy. Look at all those 4WD running around with larger
tyres. they are generally ALL unroadworthy but the Insurance companies don't 'wipe' them. Nearly every 4WD properly set up for outback touring with Bullbar, winch, roofbasket, rear
drawers,
suspension lift etc is unroadworthy as they are over GVM or have tyre/
suspension lift irregularities and the insurance companies generally pay out on them.
If the accident is caused by you and contributed to by the item that causes the vehicle to be unroadworthy then yes, they probably would 'wipe' you. But they'd have to know about it first.
