AnswerID: 158035 Submitted: Thursday, Mar 02, 2006 at 08:44
Member - Oldplodder (QLD)
replied:
Good question.
We have been thinking about the kitchen on our trailer too.
Just bought the trailer and it has a basic tailgate swing out kitchen, which needs a small upgrade.
Did think about having a kitchen that comes out the side into the main area, since ours is a side fold trailer. Advantage is that in wet or fly ridden areas we wouldn't need to put up the awning over the rear to cover the rear tailgate kitchen.
I think Freedom out of SA has such a set up.
Looking at it at the
camping show, you will get smells in the trailer, the side wall near the stove may over time build up some grease from
cooking, especially with t he window over and fumes going that way, and if you spill anything while
cooking, it will land on the main floor. Mess to clean up, but if it is also hot, you may melt the floor.
Having a zip up flap to pull the kitchen through solves the seal problem, and using that front area saves some access problems from the back, but most trailers have a lift up bed these days with gas struts.
So we are going back to a rear mounted kitchen, and will put up the awning and a small screen in that corner for fly and
weather protection if we need it.
Now the decision is, slide out or tailgate mounted :-).
Pluses and minuses to both!
 Click Image to Enlarge |
| John C - aka Oldplodder
In touring mode, the way it should be. |
Reply 9 of 12
