Section Image
f250
Submitted: Thursday, Mar 02, 2006 at 18:31
roofscooter2
hi all,just to let you know of a good report ona Ford Dealer South of Brisbane.Last June I/we bought a new Super cab F250, at the first 7,500k service when i picked it up after a couple of day's had it parked on building site on an angle & on driveway that i had to walk past it , not too unusual but i was able to notice that there was what apeared to be an oil leak. On inspection all was comfirmed,not a lot just enough. So rang dealer i thought who done the service may have done something wrong.To cut to the chase was booked in to determin the problem had truck for 7 day's problem solved,No so was booked in 2 weeks later they say we have to pull motor out to find the leak so being sceptical i went 2 day's later to check & to my horror motor was out ,talking to mechanic ,said he was preparing to pressure test it.Ok wait another 8 day's truck still not ready that was on Friday 2 weeks ago but received phone call following Wednesday truck is ready u buet & i picked it up after work. apparently leaking from sump gasket & now resealed & so far there is no sign of oil under the truck.Forgot to mention all the time they had my truck i was loaned one of their 1 tonner's.Who was it you say QFord Springwood QLD.BOB
ThreadID: 31342 Replies: 5
Views: 664 FollowUps: 7
AnswerID: 158151   Submitted: Thursday, Mar 02, 2006 at 19:00
Val replied:
It is nice when the service lives up to the rhetoric. I've changed Ford dealers because the dealer I bought the truck from had bad after-sales service. Interestingly my 250 (7.3 litre diesel) goes in on Monday to have the sump resealed for a slow oil leak just below the oil filter.
Val
Reply 1 of 5
FollowupID: 412549   Submitted: Thursday, Mar 02, 2006 at 19:25
roofscooter2 posted:
Good luck on moday Val. One of the service dept.heads that i have been under said that instead of using say(repco) sump goo as they do not use gaskets as such any more just the goo, they used genuine Ford goo this time & aparently my oil leak was an out of the ordinary place to leak,Bob.
AnswerID: 158167   Submitted: Thursday, Mar 02, 2006 at 19:35
Member - John replied:
roofscooter, surely the sump should have been sealed from new with genuine Ford stuff? Or am I missing something?
Before the last trip
Click Image to Enlarge
Reply 2 of 5
FollowupID: 412556   Submitted: Thursday, Mar 02, 2006 at 19:57
John it probably was but it is done Cuba so who knows how or what with so long as it is done effectively this time.Bob.
FollowUp 1 of 3
FollowupID: 412563   Submitted: Thursday, Mar 02, 2006 at 20:16
Exploder posted:
It’s not really goo, it’s RTV sealant it’s a silicone gasket maker can be used on everything except for Head’s due to Fuel contact issues.
My diffs and sump are also sealed with it.
If you don’t apply it right or over tighten the bolt’s it’s easy for a leek to develop, Living it to set fully is also important, would say this is what happened at factory.
There is a Loc Tight Product, can’t remember the product number that is even better but bloody expensive, If you have surface that keep’s leaking you use this stuff and is almost garneted to seal it.
FollowUp 2 of 3
FollowupID: 412570   Submitted: Thursday, Mar 02, 2006 at 20:55
thanks for the correction Ex, could not htink of what it was called so gooooooooooooooooooooo was goooood enough at this time of the day, take no offence of the reply, Bob.
FollowUp 3 of 3
AnswerID: 158176   Submitted: Thursday, Mar 02, 2006 at 20:08
roofscooter, too bloody right....................
Reply 3 of 5
AnswerID: 158197   Submitted: Thursday, Mar 02, 2006 at 21:03
Wayne (NSW) replied:
Not knowing what the sump is like on the Ford but I would have thought that a leak around the join of the sump to the motor would have been easy to pick and that the removal of the motor should not be necessary.
Seem a long time to R&R the sump even if they did give you a loan vehicle.
Wayne
Canning Stock Route 2009
Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
Reply 4 of 5
FollowupID: 412772   Submitted: Friday, Mar 03, 2006 at 13:22
the oil was showing up under the gear box through the weep holes that they have for what ever reason. Aparently there was no oil anywhere to be seen when they pulled the motor out.Bob.
FollowUp 1 of 2
FollowupID: 412818   Submitted: Friday, Mar 03, 2006 at 18:14
Utemad posted:
We had to have our F250 motor removed to fix a turbo manifold casting problem (not that they ever fixed it properly, get used to having your ute in at the dealer).
Also my Rodeo has to have the engine removed if the sump needs resealing. I say resealing because it is also goo as it does not have a gasket either.
FollowUp 2 of 2
Activities Index
2 Hour Helicopter Adventure - Whitsunday Unlimited 2 Hour Helicopter Adventure - Whitsunday Unli
The Whitsundays - QLD
Be left breathless as your panoramic flight takes you over all the high spots in and around the beau
Reef Cruise & White Water Rafting Package Reef Cruise & White Water Rafting Package
Cairns and Tropical North Queensland - QLD
NEW !!
Beer & BBQ Cooking Class - QLD Beer & BBQ Cooking Class - QLD
Brisbane - QLD
If you enjoy Great Boutique Beers & a Hearty Gourmet BBQ then this is the class for you!
Ripple 2 hr Massage for 4 - 12 people Ripple 2 hr Massage for 4 - 12 people
Byron Bay and Northern Rivers - NSW
Relaxation wherever you are!
Secrets of Eyre Peninsula 6 Day Wildlife Adventure Secrets of Eyre Peninsula 6 Day Wildlife Adve
Eyre Peninsula - SA
The Eyre Peninsula is Australia's Seafood Frontier and the 6 day tour looks to combine the best of t
Chocolate Appreciation Course - NSW Chocolate Appreciation Course - NSW
Sydney - NSW
Are you passionate about chocolate? Want to learn everything about chocolate?
Twilight Winery Experience - Swan Valley Twilight Winery Experience - Swan Valley
Perth - WA
Visit the wineries after they have closed for the day and indulge in the ambience of this wonderful
City By Lights Harley Tour- 3 Hour City By Lights Harley Tour- 3 Hour
Sydney - NSW
See the city sights and magnificent views by night.
6 Day Flinders Ranges, Coober Pedy 6 Day Flinders Ranges, Coober Pedy
Flinders Ranges - SA
On this six day tour we visit South Australia's majestic Flinders Ranges and the vast outback.
Full Day Expedition Abseiling Full Day Expedition Abseiling
Blue Mountains - NSW
Learn to abseil right in the heart of the spectacular Blue Mountains in the morning and experience t
Book Now - Things To Do
AnswerID: 159578   Submitted: Thursday, Mar 09, 2006 at 19:57
Val replied:
I have had the same good experience with Hills Ford at Waitara, north of Sydney. The 250 went in on Monday to have the sump resealed and I got it back at lunch time today (Thursday). I think it impressive that they lifted the engine out, resealed the sump and re-installed the engine in 3 & 1/2 days!! Their people skills are equally impressive. I'll be going back.
Val
Reply 5 of 5
FollowupID: 414461   Submitted: Friday, Mar 10, 2006 at 20:51
Val,good to hear you have also had a good response & out come with youre Ford Dealer.Seems that they leave the Nissan dealers in their wake lol. Keep looking for that leak!May be just coincadental but mine seems to more power in 1st & 2nd. But the economy seems a tad poorer.Good luck Val.Regards Bob.
