Site Search
Section Image
100 amp fuse in 60 amp holder
Submitted: Thursday, Mar 02, 2006 at 22:28
PK Eildon (VIC)
Bought a in-line maxi blade holder today for dual battery setup with a 100 amp fuse. Just noticed holder is rated at 60 amp. Does that mean the cable will melt before the fuse.
Click Image to Enlarge
Eildon Pondage View
Advertisement
ThreadID: 31358 Replies: 6
Views: 1319 FollowUps: 7
AnswerID: 158237   Submitted: Thursday, Mar 02, 2006 at 22:32
drivesafe replied:
No, it’s more like the holder will melt so not a real good idea.
Reply 1 of 6
AnswerID: 158238   Submitted: Thursday, Mar 02, 2006 at 22:32
Mad Dog (Australia) replied:
Doesn't sound like a good match to me, the fuse holder will melt before the fuse blows, don't know about the cable as you didn't specify what you're using.
Reply 2 of 6
FollowupID: 412619   Submitted: Thursday, Mar 02, 2006 at 22:35
Mad Dog (Australia) posted:
and fuse holders do melt but I'm interested in just what you'll be doing with this 60 amps or 100 for that matter.
FollowUp 1 of 4
FollowupID: 412622   Submitted: Thursday, Mar 02, 2006 at 22:43
ok sorry I missed it, dual battery setup. You're very unlikely to get those amount of amps flowing so stick a 40 amp fuse in and you'll be safe.
FollowUp 2 of 4
FollowupID: 412640   Submitted: Thursday, Mar 02, 2006 at 23:54
Mainey (WA) posted:
Mad Dog
I would bet my house you can get in excess of 40 Amps flowing between two batteries....
That's why every electronic battery isolator I'm aware of is rated over 100 amps.
FollowUp 3 of 4
FollowupID: 412666   Submitted: Friday, Mar 03, 2006 at 07:37
I have no doubt you could but most installations wouldn't acheive that, mine doesn't with 35mm² cable with 50% discharged aux an a deep cycle. No matter, if the fuse pops put a bigger one in...no big deal, no grey hairs.
FollowUp 4 of 4
AnswerID: 158242   Submitted: Thursday, Mar 02, 2006 at 22:45
PK Eildon (VIC) replied:
Thanks guys. Don't think I will be using it. The answers to the other questions are:
100 amp fuse on each of the + terminals recommended for Redarc when winching off both batteries, otherwise 50 amp.
The inline fuse is welded in the middle of a piece of red terminal cable. I assume the cable is rated at 60 amp.
The whole thing surprises me a bit as I went into a auto elec and asked him for a 100 amp in-line fuse and this is what he handed me. It wasn't until I got home and read the label I realised the fuse outrated the holder.
Thought there may have been a different rating system for fuses and cable.
Eildon Pondage View
Reply 3 of 6
FollowupID: 412651   Submitted: Friday, Mar 03, 2006 at 05:46
Kiwi Kia posted:
No real problem at all if the fuse is there in case of a short circuit. If your 'normal' operating load is over 60 amps then you are going to have a problem.
The cable rating takes into account the operating temperature and several other factors and will happily carry well in excess of 60 amps for some time till the temperature rise starts to melt the insulation and may cause a fire.
With a large MAIN fuse the instant full load current when you are starting or winching can be carried without blowing the main fuse and your individual circuit fuses should protect you from the normal operating constant current.
FollowUp 1 of 2
FollowupID: 412678   Submitted: Friday, Mar 03, 2006 at 08:09
Leroy posted:
If you are planning on winching, I wouldn't install a fuse. A winch under load will draw more than 100amps! Your starter motor in your car generally doesn't have a fuse as it's not practical hence not practical for a winch either. I'd install a fuse on the second battery for your aux outlets only if you feel the need but even I haven't done that but thenn the cable I use has thick insulation and is inside split tube. The narva cct breaker is waiting for it's chance to be installed......one day :-)
Leroy
PS I use a Redarc and a winch.
FollowUp 2 of 2
AnswerID: 158285   Submitted: Friday, Mar 03, 2006 at 07:30
Derek from Affordable Batteries & Radiators replied:
If you plan on winching or jump starting off this circuit you can't use a fuse.
The fuse will blow and if you are in the sticks you will have to bodge the wiring to get the thing to work again.
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 4 of 6
Activities Index
Hunter Valley Hunter Valley 'Private Charter' 4WD Tour for
Sydney - NSW
Discover the best kept secrets of the Hunter Valley you thought you knew!
One-On-One Skateboard Lesson One-On-One Skateboard Lesson
Sydney - NSW
This skateboard lesson in Sydney is a great experience for all skaters, or those looking to learn.
Stand up Paddle Boarding + Bonus T-shirt Stand up Paddle Boarding + Bonus T-shirt
Melbourne - VIC
A 2 hour Stand Up Paddle Boarding Group Lesson at St Kilda as well a Stand Up Paddle Boarding T-Shir
Relaxation Massage Relaxation Massage
Sydney - NSW
We understand the pressures of everyday life and the importance of relaxation.
Book Now - Things To Do
AnswerID: 158313   Submitted: Friday, Mar 03, 2006 at 09:51
Sounds like my best option may be "no fuses" and battery connectors on neg posts with those green disconnection knobs in case things look too hot under bonnet.
Eildon Pondage View
Reply 5 of 6
FollowupID: 412978   Submitted: Saturday, Mar 04, 2006 at 11:17
Mike DiD posted:
If you are going to be using a big winch that will draw hundreds of amps, I would run a heavy cable between the two batteries that can take the winching current. In the middle of this cable put one of those battery isolating switches with the green knob. Only close this switch when winching.
Run a separate wire (100amp) between the battery positives that runs via the Battery Isolator and is fused.
Mike
AnswerID: 158464   Submitted: Saturday, Mar 04, 2006 at 06:33
gen3rules replied:
If you are so keen to use a fuse of that size try a caterpillar type manual reset circuit breaker these come in a large range and in my opinion are far superior to fuses and auto reset circuit breakers designed for automotive use. If there is no cat agent close by kenworth dealers also can source them.
Reply 6 of 6
