LC 100 series fuses??
Submitted: Sunday, Mar 05, 2006 at 14:56
ThreadID: 31433 Views:15855 Replies:4 FollowUps:2
The 12 volt outlet socket at the back of my 100 series TD Landcruiser hasn't worked since I bought it.
Does anyone know which fuse supplies that socket? I've checked all the fuses located near the passenger side battery and they all seem OK. Are there any other fuses anywhere?
Thanks,
Bilbo
Reply By: japmel - Sunday, Mar 05, 2006 at 15:26
Both the Drivers side and Passengers side kick panels have Fuses behind them.
japmel
AnswerID: 158706
Follow Up By: japmel - Sunday, Mar 05, 2006 at 15:47
I just had a look in the Manuel,
I think the fuse you want is Behind the passenger side kick panel,
It should be the top left hand side one, Number 27 in the book 15amp.
Hope that helps.
japmel
FollowupID: 413206
Reply By: Member - Mark S (S/Coast QLD) - Monday, Mar 06, 2006 at 08:49
If i remember correctly, i think you will find a fuse behind the actual socket itself. You will have to take the panel off that is attached to the socket.
Mark.
AnswerID: 158834
Reply By: OMN - Monday, Mar 06, 2006 at 09:58
There is also a main fuse box under the bonnet, but dont think that one does what you are looking for.
Have you tried the simple approach of asking a dealership, even if you boguth it senond hand, which is the right fuse.
Generally they are happy to provide info, i know when my exhaust, which is aftermarket, had problems the only place in Mansfield that was helpful was the service guy at Toyota and he didnt want any money for the bolts or advice.
Mark
AnswerID: 158840
Reply By: Bilbo - Monday, Mar 06, 2006 at 19:19
OMN - can't do that today - they're all closed. It's Labour day over 'ere in the best state in Australia - W.A. We pay all the bills, remember?
I've tried pulling the fuse from the fuse board from the fuseblock located at the passenger side kick panel. That's a 15 amp fuse and when pulled, the front 10 amp power outlet has no voltage. Thus, I would surmise that this fuse is only for the front outlet. i.e the outlet is 10 amp and the fuse is 15 amp. A 15 amp fuse would blow if both the rear and the front oulets were being used at the same time.
If there is a fuse at the back of the rear power outlet, can anyone tell me how to get at it. I can't even get my hand in there to feel the back of the socket. Is there an easy way to pull out the socket, without having to take out all the side panelling - not to mention the whole of an Outback Drawer System!
Thanks,
Bilbo
AnswerID: 158941
Follow Up By: crewser - Tuesday, Mar 07, 2006 at 18:55
theres no fuse at the back of the power outlet (not on the 20 odd 100s cruisers Ive pulled apart anyway) and theres no easy way to pull the socket out even when the panel is removed. there is a plug on the rear of the power socket maybe this has been disconected.
FollowupID: 413653
