Custom Steel Rims
Submitted: Thursday, Mar 09, 2006 at 17:03
BennHW
Hi ... Anyone out there had experience with purchasing/using custom steel rims?
I want to upgrade my fourby from 30" to to 31" tyres which means going from factory 6.5" width rims up to 15" x 7" - 8" rims.
No supplier I can find has an off-the-shelf steel rim with sufficient off-set. (I need 3.5" to 3.75" positive off-set on a 15" x 8" rim.)
I see that ROH do custom steel rims, but I was wondering whether anyone has been through the process of buying custom
wheels and can suggest a good supplier and what to watch out for - and give me an idea of price. (I'm based in
Brisbane.)
And yes, I've looked into alloys ... They're expensive and the choices are few. My preference is steel - even though I've never had a problem with the factory alloys I've got.
Thanks in advance for any suggestions/help.
Benn
Reply By: Member - Oldplodder (QLD) - Thursday, Mar 09, 2006 at 17:24
I have had custom steel rims made for the racing rubber on the beetle.
In
Brisbane I use Race Engineering.
I supply a standard rim for the centre, and they cut the centre out and weld a rim of the width I require on.
You need to tell them the offset you require.
e.g. - stock rim - 15"x4.5", they return a 15"x7".
Cost - varies on finish but about $120.00 per rim, with a powder coat finish.
Can be $90.00 per rim if you do your own finish.
159535
Follow Up By: BennHW - Thursday, Mar 09, 2006 at 17:38
Great information. Thanks "OldPlodder". Much appreciated.
414165
Follow Up By: Member - Willie , Epping .Syd. - Thursday, Mar 09, 2006 at 18:08
Old Plodder unmasked - not such a plodder after all - raced a beetle - that would have been fun in the wet .
Cheers ,
Willie .
( also a " past it "revhead )
414173
