O/T Black marker pens
Submitted: Tuesday, Mar 14, 2006 at 23:29
ThreadID: 31744 Views:2219 Replies:5 FollowUps:2
I have an accessory that I want to install in the cabin of my 4wd but someone has used black marker pen on its plastic. I also have grey painted metal elsewhere with the same problem. Is there a successful way of removing it without using a steel brush and re finishing it ?
Reply By: Member - David 0- Tuesday, Mar 14, 2006 at 23:34
Footloose
Get a pen the same, and a paper towel. Rub the marker pen over the original writing and before it dries wipe hard with paper towel. Try on most inconspicuous spot first
AnswerID: 160567
Reply By: Member - Mike DID - Tuesday, Mar 14, 2006 at 23:35
Metho or Lacquer Thinner - but test it on an inconspicuous area to see if it will affect the plastic.
Mike
AnswerID: 160568
Reply By: ro-dah-o (WA) - Wednesday, Mar 15, 2006 at 00:05
if its a permanent marker, goe over it with a white board marker and rub off asap. Old trainers tip from way back.
I hate it when those pens look the same......
AnswerID: 160571
Follow Up By: Rosco - Qld - Wednesday, Mar 15, 2006 at 09:19
Spot on
Get's my vote too.
FollowupID: 415417
Reply By: Barnray - Wednesday, Mar 15, 2006 at 07:27
Use aeroguard but test it first, we use it to remove grafitti of our shop wall. Barnray
AnswerID: 160584
Follow Up By: Groove - Wednesday, Mar 15, 2006 at 08:16
Carefull with insect repellants I have had them do some serious damage to plastics.
Second the whiteboard marker method use it often.
FollowupID: 415392
Reply By: Shaker - Wednesday, Mar 15, 2006 at 09:53
According to the experts, you get a marker of the same type, mark over the top of the existing marks & quickly wipe off, if there is a lot you would only do a small section at a time.
AnswerID: 160600
