cummins m11
Submitted: Wednesday, Mar 15, 2006 at 22:48
ThreadID: 31786 Views:4019 Replies:2 FollowUps:1
does any one know what the celect codes idle switch in a kenworth t480 fitted with a cummins m11 engine is for?????????
Reply By: Member - Doug T (QLD) - Wednesday, Mar 15, 2006 at 23:11
It is I think to give you the codes for when there is a fault that the engine management computer registers,Those codes then relate to the fault and then the Mechanic knows where to look and fix/replace ,I was driving an International S-Line with a M-11 Cummins and the damn thing shut down the motor near Injune , was there all day untill someone arrived from Emerald, bloody computers,[ excuse my language all the Poms out there, ]Diagnostic Codes is the correct name.
AnswerID: 160794
Follow Up By: Member - Doug T (QLD) - Wednesday, Mar 15, 2006 at 23:16
Check out this site
cummins
FollowupID: 415567
Reply By: dieselman - Thursday, Mar 16, 2006 at 21:11
Egg,
This switch will adjust the idle revs up and down if the feature is enabled(Idle speed adjustment) and when the switch is held up with only the key on(engine not running) it will flash out any active fault codes.
Hope this helps
Dieselman
AnswerID: 161017
