accelerator pedal vibration.
Submitted: Monday, Mar 20, 2006 at 01:23
ThreadID: 31916 Views:4399 Replies:2 FollowUps:4
Anyone experiencing vibration throught the accelerator pedal.
I put up with it for nearly 8 months till it was so bad that it was easier to see.
I found that the vibration came from the part where the end of the accelerator cable connects to a arm near the motor.
The main part is secured to the motor with two bolts. Both of these could be tightened with fingers. I tightened them and now things are back to normal oh soooooooo smooth and no vibration. Hopefully this will give those somewhere to start.
Reply By: Gerry - Monday, Mar 20, 2006 at 09:34
Hi Gaz,
What sort of vehicle mate? Have some vibration in my 100 series, although not too bad.
Gerry
AnswerID: 161629
Follow Up By: WA Gaz - Monday, Mar 20, 2006 at 09:49
Hi Gerry,
Mine is a Patrol 4.2 DX 2000 model. It just about drove me crazy but now its normal. Check the bolts that hold it on. Maybe its from there.
Gaz
FollowupID: 416341
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 20, 2006 at 10:33
my 4.2 is the same, I get out of it after a long drive and my foot tingles for an hour!!! Nissan reckons its ok, but what would you expect them to say!
FollowupID: 416354
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 20, 2006 at 10:36
i will look at that Gaz!! many thanks.
FollowupID: 416356
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 20, 2006 at 10:38
A few people posted a few months ago, including myself about this problem,, It would be very pleasant for all if this the problem for the others..
FollowupID: 416357
Reply By: 120scruiser - Monday, Mar 20, 2006 at 20:24
I had one come through the workshop a couple of weeks ago.
A 2002 v6 hilux and when I popped the bonnet I could see the clamp that holds the
accelerator cable near the shroud had let the cable pop out and the cable was hitting the fan. Slipped it back in to the clamp and no more vibration.
AnswerID: 161750
