nissan tray back water tanks
Submitted: Monday, Mar 20, 2006 at 15:23
donnnnny
Hello again from
sydney's latest nissan owner. Ive noticed under the tray ajacent to the sub
tank(behing passengers
seat) there is a huge space which would be ideal for a permenant
water tank set up. Have any other nissan owners utilised this space in the same way i am thinking of.?
if so can you point me in the right direction for a fabricator(stainless steel tanks )in the weston
sydney area. I recon should be able to get a pretty good size
tank inthe space. its in front of the rear axel and low down.
cheers don
Reply By: pmacks - Monday, Mar 20, 2006 at 16:14
talk to paul or tommy at Brightweld 9676 7719 they are at
Kings Park on garling Rd
down the same drive way as TJM very good at what they do. They are specialist Stainless Steel fabricators.
As always no i dont work there have no affiliation other than as satisfied customer
Good luck
pmacks
161696
Reply By: PK Eildon (VIC) - Monday, Mar 20, 2006 at 16:31
Just something to think about with
water if you are going 'remote'. If you have all your
water in the 1
tank and something goes awry - no
water. Thats why I prefer several 20 litre plastic - unlikely to loose the lot.
161697
Follow Up By: Member - Charlie S (VIC) - Monday, Mar 20, 2006 at 17:08
That's true. I had a similar set up with a separator and two fillers. (Basically two tanks) Also helps with baffling.
416392
Reply By: Mr Z - Monday, Mar 20, 2006 at 21:24
i've installed a
tank in that space,
however i used a pvc
tank designed for a caravan, it was about $80 new + a few fittings. it holds 70l i think, and is gravity fed.
works
well, and was a cheap set up
161770
Reply By: Member - Craig D (SA) - Tuesday, Mar 21, 2006 at 07:58
Goughs make an 80 litre undertray
tank with multiple take-off points if that's any help.
161832
