Transfer gears on 2003 hilux
Submitted: Monday, Mar 20, 2006 at 17:49
ThreadID: 31944 Views:2592 Replies:4 FollowUps:2
g'day all,
Im wanting to put either BFG 33/10.5x15 AT's or Cooper ST 285/75x16 on my 2003 Hilux V6. What my concern is, with my current 265/75x16 BFG's they sap alot of power from hilux. It's not bad once the hilux is up and moving but it's getting off the line that's the problem, it feels like it's lacking torque!
Which is why I'd like to replace the high and low gears on my transfer case with the bigger tyres im thinking of putting on. I want the car to accelerate in high range slightly slower than stock (I reckon they were geared wrong from the factory which is why alot of V6's blew rear diffs), and the low range to allow me to not quite crawl, but abit slower than the previous models 3.0litre diesel did in low range.
I dont know where to go to get this done right in Melbourne(west or north preferably) and which ratios should I get fitted to give me the driving characteristics im after, and how much would it set me back?
any advice is appreciated,
TUFF IFS LUX
Reply By: Member - Bill S (NSW) - Monday, Mar 20, 2006 at 19:38
HI , Do not know about 2003 model but earlier model has a chain driven transfer case drive,with no tensioner. So good luck in your endevours.
Regards BILLS
AnswerID: 161740
Reply By: c j - Monday, Mar 20, 2006 at 20:46
The Hilux has a 1:1 pass through high I think so if you want to change high range then you will need to change diff ratios. There are low range options.
http://www.marks4wd.com/Hilux-extra-low-tc-gears.htm
http://www.bbmotorsports.com.au/prod473.htm
AnswerID: 161761
Reply By: Sarg - Monday, Mar 20, 2006 at 21:36
Try some number crunching on this & see what suits you best.
Changing transfere case gears wont do it, you will have to change the diff(s) ratio
http://www.osella.com.au/gear-ratios.htm
AnswerID: 161776
Follow Up By: Sarg - Monday, Mar 20, 2006 at 22:57
Or this -
http://www.dfw-tx4wd.org/Tech-Dept/Tech-Dept/gearstable.htm
FollowupID: 416464
Reply By: 4runner - Tuesday, Mar 21, 2006 at 00:07
Dont meddle with the transfer gears as that wont help. You need to change both the front and rear difff ratios to get the that extra oomph that you are after. Try the snakeracing website as they have a an extensive range of diff ratios and will probably find one to suit your needs. But remember to change the speedo drive gear where the speedo cable goes into the gearbox. Not difficult to do. If you dont change the speedo drive gear, you willl have a speedometer that is grossly over or under reading. But to err on eh side of caution and have a speedo that over reads. Mine over reads by 5 KMH. Hope that helps.
AnswerID: 161803
Follow Up By: TUFF IFS LUX - Tuesday, Mar 21, 2006 at 20:42
ive fitted meself the Marks Adaptors variable ratio box which corrected perfectly the speedo, which was 9% out of wack with the 265/75x16 tyres fitted. good product, easy to install and works well.
Just thought I'd mention that.
TUFF IFS LUX
FollowupID: 416697
