GU DIN slot-removal
Submitted: Tuesday, Mar 21, 2006 at 12:45
lizard
Is there an easy way to get the existing 'box' out of the Din void , so I can fit my Uniden in ? Vehicle is a 2005 GU Cab chassis
Reply By: Member - Troll 81 (QLD) - Tuesday, Mar 21, 2006 at 13:00
If the setup is the same as the 99 then everything around the radio area comes apart. You should see 2 little slots towards the bottom of the panel, stick a flat head screwdriver in there and give it a little twist and it will just pop out.
161906
Follow Up By: Leroy - Tuesday, Mar 21, 2006 at 13:27
'stick a flat head screwdriver in there and give it a little twist and it will just pop out.'
after you take the 2 screws out the bottom!!
Leroy
416558
Reply By: Member - Craig D (SA) - Tuesday, Mar 21, 2006 at 13:15
See post 16289.
161915
Reply By: lizard - Tuesday, Mar 21, 2006 at 20:13
Thanks for the advice , checked it out - cheers
162025
